Coolant Temp Sensor
Old Mar 7, 2012 | 04:46 PM
kdtomczak's Avatar
kdtomczak
Default Coolant Temp Sensor
I never get a coolant temperature on my dash now...just "LO".
I want to replace the sensor and the wiring that goes with it but I want to know where it is located first before I decide to jump on this job myself. Where is it located? TIA!
1986 coupe.
Old Mar 7, 2012 | 05:32 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Passenger side head. Spade connector, green wire.
Old Mar 7, 2012 | 07:58 PM
Cliff Harris's Avatar
Cliff Harris
If it reads LO all the time it means the circuit is open or the sensor is broken.
There is a magic number that it will read if the circuit is shorted, but I don't remember off hand what it is. 384 degrees?
Old Mar 7, 2012 | 10:14 PM
kdtomczak's Avatar
kdtomczak
so chances are, the sensor is broken?
Old Mar 7, 2012 | 10:44 PM
gunnerjuju's Avatar
gunnerjuju
on mine it was just discinnected when it read "Lo" all the time
Old Mar 8, 2012 | 01:07 AM
Cliff Harris
The sensor contact might be corroded enough that it doesn't make a connection.
Another possibility is that the wire is broken inside the insulation or at the pin inside the connector.
Disconnect the wire from the sensor and ground the connector pin. You should see the "magic number" on the display. If that happens then the wiring is good and the only thing left is the sensor.
To Coolant Temp Sensor
