Fixed temp reading
Old Mar 12, 2012 | 05:00 PM
illenema's Avatar
illenema
Default Fixed temp reading
Anybody every experienced a Fixed temperature on the digital portion of the gauges?? 142 Degrees to be exact
Old Mar 12, 2012 | 07:00 PM
illenema's Avatar
illenema
All fixed. new sensor, even when the old sensor read proper ohm readings
Old Mar 12, 2012 | 07:13 PM
raiderz's Avatar
raiderz
My digital dash 86 coupe is reading 10 degrees F higher than the ECM reading on the Datamaster scans i do. This only started right after i installed a new Edelbrock reverse flow water pump...strictly a coincidence......
Sound like the sender in the passenger head is faulty or the digital dash (grounds)??
Old Mar 12, 2012 | 10:00 PM
illenema's Avatar
illenema
10 degrees I would not ne concerned myself.
I was starting to freak out on this as all the voltages and ohm readings were correct, as the engine warmed up the resistance changed according to the Service manual charts.
Popped in that 10$ ebay exact replacment and all normal again.
that coolant sensor on the water pump controls how the ecm sends info and that engine went from great to ****. all while the analog gauge read proper temps. Someone unfamiliar with the dual coolant sensor set up would be in for some rough times. Ha
Old Mar 13, 2012 | 03:41 AM
Cliff Harris's Avatar
Cliff Harris
It's normal for the dash to read 10 degrees higher than the ECM. The water coming from the radiator and hitting the ECM sensor in the front of the intake manifold is cooler than the water in the back of the passenger side head, where the dash temperature sensor is located.
Old Mar 13, 2012 | 04:21 PM
raiderz's Avatar
raiderz
Makes sense in theory...but then, what would be the purpose of have the sender in the head if it is not going to be close to accurate.
Before my readings changed recently...my dash was within 2 degreEs of the reading from the ECM.
Im going to pop in a new $9 sensor in the head to see if anything changes.
To Fixed temp reading
