C4 MPH cluster does not work
Old Mar 14, 2012 | 07:39 PM
rortizjr's Avatar
rortizjr
Default C4 MPH cluster does not work
Greetings, the MPH electronic display does not work, all other display gauges are working. I just now get a check engine light and when I checked the error code it says "no vehicle speed signal recieved", coule it be that the vehicle speed sensor is bad or is it the wiring from the VSS to the ECM?
Old Mar 14, 2012 | 08:35 PM
cgantner5150's Avatar
cgantner5150
If you have no reading on the dash gauge it is either the speed sensor in the tranny or the wiring between the tranny and the dash. The VSS feeds the dash and the dash feeds the ECM.
Old Mar 14, 2012 | 08:54 PM
rortizjr's Avatar
rortizjr
is there a simple way to check where the problem is? i am not good with wiring situations, should i replace the vss to see if that is the problem, not sure what my next steps should be
Old Mar 14, 2012 | 09:14 PM
black-93-coupe's Avatar
black-93-coupe
What year is your car, because I'm having a hard time finding a vss for my 93 automatic. My car has the D8K speed sensor, gm part #10456091.
Old Mar 15, 2012 | 04:26 AM
rortizjr's Avatar
rortizjr
my is a 1985
Old Mar 15, 2012 | 03:46 PM
rortizjr's Avatar
rortizjr
update, as I was driving today the MPH gauge actually worked for a few minutes, it was fluctuating and then it stopped again. this happen twice Do you think it could be a wiring issue or is the VSS bad?
Old Mar 16, 2012 | 04:03 AM
Cliff Harris's Avatar
Cliff Harris
More likely an intermittent problem in the instrument cluster. They are well known for having solder joints go bad over time. There are some threads here on repairing the cluster.
Old Mar 19, 2012 | 05:09 PM
rortizjr's Avatar
rortizjr
Default 1985 Corvette RPM Issue
Greetings my corvette family, after driving a short distance and then idle, my 1984 vette rpms start to range from 1400 to 1700 rpms. is it possible to adjust the rpms to a lower setting, if so, how do i do it?
Old Mar 20, 2012 | 05:31 PM
corvetero's Avatar
corvetero
Originally Posted by Cliff Harris
More likely an intermittent problem in the instrument cluster. They are well know for having solder joints go bad over time. There are some threads here on repairing the cluster.
Could you please showme the link to any thread regarding this issue for a 92?
Old Jul 23, 2012 | 03:08 AM
ChevyGuyScott's Avatar
ChevyGuyScott
I am and Have been having a similar issue for about a year now...
The speedo and gas gauge turn on and off, and the tach seems to be reading inaccurate. all the other gauges work fine as well as the back lighting. It has gotten progressively worse, I used to be able to smack the dash or push on the gauges and it would work for awhile. then I started getting "SYS" flashing in the MPH area. (when it was working) I thought it was a connection issue so I pulled it all out and cleaned all the connections and made sure everything was tight but no luck.
It's a 91 w/digital mph / gas and analog rest
Old Jul 23, 2012 | 06:39 AM
HlhnEast's Avatar
HlhnEast
OK, everybody asking here can go to batee.com and look at his Corvette repair section. Sorry Corvetero, this wont apply to you because its for the Atari dash only. After looking at the wiring diagrams, find which pin that connects the dash has the speed function and check it with a DVM to see if you have a steady voltage coming in. Not sure what the range is (thats what the website is for) and you may actually have to be moving to get a reading. I dunno, this was not an issue I faced. If you do have your reading, check again and see which pin on the 10 pin molex connector between the PCB's relays speed function from one to another and you can maybe spot a bad solder joint or bad pin connections. I had a problem with my lighting and I actually soldered a jumper wire around this connector.
Heres your link. Take time to click a couple of the ads as Brian gets paid and it helps keep the website up.
http://batee.com/corvette/index.htm
To C4 MPH cluster does not work
