Head light question
Old Apr 1, 2012 | 05:19 PM
95VetteMan1's Avatar
95VetteMan1
Default Head light question
Ok this is a weird question..my passenger light will not raise correctly..My mechanic says its the Head light door module..My question is this attached to the motor?
Old Apr 1, 2012 | 05:29 PM
Klondike's Avatar
Klondike
More than likely it is the gell pellets in the motor gear box have gone bad and disentigrated. Common problem. There are 3 little hard plastic "pucks" about the size of your finger tip that are a shock damper between the motor driven gear and the axle piece that turns and lifts the headlight bucket. When they go bad, the gear will slip and the headlight will get floppy and not come up like it should. There are lots of posts here about how to fix that. It's not hard, but I don't have a link to it handy.
Old Apr 1, 2012 | 07:55 PM
Wildride's Avatar
Wildride
Cruise-In II Veteran
How to do it:
http://forums.corvetteforum.com/c4-t...air-w-pic.html
I got my bushing at my local Ace Hardware. $1.50 or so total cost.
Old Apr 1, 2012 | 09:19 PM
mrmtrtrnd's Avatar
mrmtrtrnd
Replaced mine last year.
Old Apr 3, 2012 | 03:27 PM
Vulcan2000's Avatar
Vulcan2000
Navigator
Originally Posted by Wildride
How to do it:
Do you remember the size etc of the bushings you got at Ace?
Old Apr 3, 2012 | 04:09 PM
aminnich's Avatar
aminnich
If the motor runs then the answers above are the way to go. If not the module is in the well in front of the driver's side front wheel. Little black box about 3"X5" and expensive for it's size.
Old Apr 3, 2012 | 04:43 PM
Wildride's Avatar
Wildride
I used bushings from my local ACE Hardware-$1.50 for six (three needed for each headlight). Some have used bushings from Home Depot (the part number used to be 3069987278 or 030699872787 and the part name on the package is "spacer".
I also understand that Ford power window mechanism bushings work (Advance Auto or Auto Zone "HELP" section.
The nominal size I have scribbled down was 27/64 by 29/64. Which is length vs. diameter I don't recall.
Old Apr 3, 2012 | 04:58 PM
Vulcan2000's Avatar
Vulcan2000
Navigator
Thanks very much, I'll check at Home Depot and Auto shops!
Old Apr 5, 2012 | 08:37 PM
Vulcan2000's Avatar
Vulcan2000
Navigator
Thanks for the info. I found the spacers at Home Depot. I re-built the motor today in less than 1 hour (a 2 beer job). Total expense was $1.43. Pretty easy job overall.
To Head light question
