90 headlight problem
Old Apr 6, 2012 | 10:28 AM
mphy98's Avatar
mphy98
Default 90 headlight problem
ok last year I replaced the headlight controll module with another one I bought from Ebay. It was used, but the lights did turn. I only had a problem with the passenger side but the module cured that. Now after storage it strikes again. The passenger side does not work again. Could it be possible to have another module go out so soon? is there a test for it? If I need one does anyone have one that works for me? thanks for your suggestions, Bob
Old Apr 6, 2012 | 01:50 PM
mickey5's Avatar
mickey5
Does the motor run but the headlight not rotate? If so it could be the bushings in the gearbox need to be replaced. Very common problem on these cars after 20 odd years.
Old Apr 6, 2012 | 03:29 PM
mphy98's Avatar
mphy98
no motor turning, it has to the module or broken wire, more likley the module. I wish there was a test for this.
To 90 headlight problem
