Anything else I've forgotten...
Old Apr 22, 2012 | 08:23 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Default Anything else I've forgotten...
The engine is ready to drop in.
But before I get started, what else should I do?
Replace the water pump? Fuel lines?
Old Apr 22, 2012 | 08:29 PM
ch@0s's Avatar
ch@0s
Clean and pain the engine bay?
Old Apr 22, 2012 | 09:26 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
When I did this on a C3 I had the original starter and alternator rebuilt even though they did not need it. Now is also a good time to replace the oil sending unit, knock sensors, tach filter. Good time for a rebuilt tranny and new clutch or torque converter.
Old Apr 22, 2012 | 10:10 PM
JackDidley's Avatar
JackDidley
If the rubber fuel lines are original, Id replace them. Nearly impossible once the motor is in there. Bottom radiator hose maybe ? Motor mounts ? Exhaust studs ? Just throwing things out there.
Old Apr 23, 2012 | 12:40 AM
JrRifleCoach
Check!
Check, Check, relocated the filter for easy access, Check, Check! Tranny & TC rebuilt/new
Ugh fuel lines, Maybe the SS braided kind.... anyone have a source? Check, Check!
Ron, I really wanted to get the big tubes and intake ported.
After sinking my "power" budget back into the transmission, This will have to wait until next winter.
Old Apr 23, 2012 | 08:48 AM
JackDidley's Avatar
JackDidley
I used the teflon core SS braided lines. Its real easy to work with and not effected by alcohol. You can get it from Summitt. The big thing is getting the right adapters. 6 AN to Saginaw. The ones at the intake are 2 different sizes on the early TPI cars.
Old Apr 23, 2012 | 10:16 AM
ch@0s's Avatar
ch@0s
I have a 16mm male to AN -6 male fitting you can have just pay shipping if you can used it. Early TPI is 16mm and 14mm IIRC and the late are two 16mm.
Old Apr 23, 2012 | 12:15 PM
JrRifleCoach
Calling Summit this morning....
Old May 9, 2012 | 11:04 PM
JrRifleCoach
Slowly, slowly, the work progresses.
Broken O2 connector. $23 @ Chevy house $13 at NAPA
Rad hoses. Pulley set.
Trim the hedges, plant the garden, take out the trash.........
Hopefully done for Vette Magic in three weeks
Old May 9, 2012 | 11:09 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
If you'd like to save a few bucks you could use the aluminum hard line to replace your rubber fuel lines. I had braided stainless with rubber liner that I did not trust, it had been on the car about 4 years. I got a 10 ft. roll of the aluminum and use tube nuts & tube sleeves. It's a little harder to work with but at least it won't deteriorate.
Old May 10, 2012 | 12:01 AM
JrRifleCoach
After lots of research time, I removed the fuel lines and pressure tested at 100 PSI.
No leakys.
Good to go!
Thanks for your suggestion.
Old May 10, 2012 | 11:14 PM
flannel_man's Avatar
flannel_man
Cruise-In VI Veteran
rebuild or crate? replace vacuum lines, drain brake resivoirs then flush brake fluid, flush clutch MC, replace fuel filter, replace serp belt, replace wire loom
To Anything else I've forgotten...
