1985 vette idle
Old Apr 27, 2012 | 07:25 AM
rortizjr's Avatar
rortizjr
Default 1985 vette idle
My 1985 vette idles very fast, 1700 - 1900 rpms all the time, how do I adjust it? The speed indicator on my LCD screen does not work and sometimes I get an check engine light with the code that the vss is not recongize, not sure if this is affecting the idle
Old Apr 27, 2012 | 08:03 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Did this problem just start ?
Have you checked for cable or linkage binding ?
Have you checked for a vacuum leak ?
Old Apr 27, 2012 | 10:19 AM
rortizjr's Avatar
rortizjr
it started recently, i will need to check about the cable-linkage and i had to replace the air diverter module since it broke when the serpentine belt broke, not sure if i connected the air system correctly.
To 1985 vette idle
