Amp placement
Old Apr 29, 2012 | 05:22 PM
lespaul4563's Avatar
lespaul4563
Default Amp placement
Hi, I'm thinking about putting my amp under the pass seat(Not power). Is there any think i need to watch out for if i screw it down?
Old Apr 29, 2012 | 05:56 PM
StealthLT4's Avatar
StealthLT4
Just be sure the seat clears it. Other good amp locations are behind the passenger seat, if you don't have anyone too tall riding with you. Mine is under the rear cargo tray, where the jack and factory radio "brain" used to be, so it's out of sight.
Old Apr 30, 2012 | 08:24 AM
HlhnEast's Avatar
HlhnEast
The PO of my car placed amps behind both seats and it was the first thing I snatched out because it robbed too much room and made the car uncomfortable for me. I guess if you were less than 6' it might be a good location.
Old Apr 30, 2012 | 08:30 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I have my amp under the seat. I needed to trim some unseen plastic on the bottom back area. I also added 1/4" spacers between the seat track and floor. I have a huge amp, so you may get away without any mods.
I had my first amp behind the seat, bit didn't like how it moved the seat forward, to clear. Still worked fine, but when I sat in there, I felt I was too close to the dash.
Old Apr 30, 2012 | 08:53 AM
VetteMed's Avatar
VetteMed
I'm not tall (5'9" at best), and I'm running a small amp, so it's mounted on the bulkhead behind the driver's seat. Still have plenty of room around the amp for cooling, and I can drive in a comfortable position.
Old May 1, 2012 | 12:04 AM
lespaul4563
@StealthLT4 Is that what that is? haha I've been wondering for awhile what that was. And @AGENT 86 I think I'm going to try that. Where did you take the remote wire for the amp from?
Old May 1, 2012 | 07:51 AM
AGENT 86's Avatar
AGENT 86
My head unit has remote out for amp. What is your head unit going to be ?
To Amp placement
