85-89 console plate help
Old May 8, 2012 | 10:07 AM
LD85's Avatar
LD85
Default 85-89 console plate help
Anybody try to use an automatic console plate on a stick tranny?
They don't make the stick console plate any more, or at least I cant find one.
Old May 8, 2012 | 12:59 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
I'm just flying blind here but could you take the piece out between the auto shifter hole & the gear indicator?
Old May 8, 2012 | 01:29 PM
slickfx3's Avatar
slickfx3
89 is zf6 they are different and you know they come used
Old May 8, 2012 | 04:06 PM
LD85's Avatar
LD85
In dont mind cutting the indicator slot out, not at all.
Old May 9, 2012 | 11:04 AM
Keystring's Avatar
Keystring
Sure, you could cut it out.
You might have to make your own boot, but that shouldn't be too hard to do.
Old May 10, 2012 | 12:53 PM
HlhnEast's Avatar
HlhnEast
I happen to have a NOS piece but dont know if its actually GM as I cant find any OEM stamp on it. I didnt use it on my 85 because my OD switch is on the console and this plate is set up for the shifter switch. It would probly work good for your Tremec.
Old May 10, 2012 | 01:23 PM
cgantner5150's Avatar
cgantner5150
I have one for a 4+3 that I swapped out. It's not perfect but you can have it if you need it.
To 85-89 console plate help
