"SYS" blinking on display???
Old May 21, 2002 | 07:15 PM
tropicaltim's Avatar
tropicaltim
Default "SYS" blinking on display???
Any ideas what this might mean. Not all the time but it is quite frequently, How do I find out what it means, and how do I fix it. Car seems fine to me??
Old May 21, 2002 | 07:46 PM
behnevette's Avatar
behnevette
Default Re: "SYS" blinking on display??? (tropicaltim)
Have you replaced the stereo system lately? If not, it's probably your battery.
carter200's Avatar
carter200
Time to throw it away and buy a new one :jester
Old May 21, 2002 | 08:02 PM
Drewdog's Avatar
Drewdog
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: "SYS" blinking on display??? (carter200)
change your battery
Old May 21, 2002 | 08:09 PM
J Z06's Avatar
J Z06
Default Re: "SYS" blinking on display??? (behnevette)
Right on. After my stock system was yanked..SYS has been flashing since(1998) Doesn't bother me in the least.
Old May 21, 2002 | 08:39 PM
bac22's Avatar
bac22
Default Re: "SYS" blinking on display??? (JD 90 383)
There is numerous things it could mean. It is telling you the ECM has register an error code. Usually when the battery voltage drops below a certain level that will cause it and seems to be the most common problem. You can try disconnecting the battery for 10 seconds to allow the ECM to clear and then wait to see if it comes back. The ECM stores codes forever so it could be a old code.
Old May 21, 2002 | 09:28 PM
TA's Avatar
TA
Default Re: "SYS" blinking on display??? (bac22)
I just had the same thing after installing an aftermarket chip in my car. I took it back out repositioned it and the SYS message went away. :confused:
Old May 21, 2002 | 10:30 PM
PoloGrn96's Avatar
PoloGrn96
Cruising
Default Re: "SYS" blinking on display??? (TA)
I had the same issue when the stock stereo was replaced. The way I understood the problem was that the original stereo basically, through voltage, told the onboard computer that the stereo is there and alive. Replacing the unit left an unused harness wire that made an open circuit. The installer had to install a resistored wire to compensate... btw, it took the Chevy dealership to diagnose the problem so that the sound system installer could fix the issue... lots of fun...
Old May 21, 2002 | 11:35 PM
DHealey's Avatar
DHealey
My 92 had the SYS light flashing occasionally, like 3 blinks , then off for a while, 3 blinks etc. Another forum member told me it was an undocumented feature telling me the battery is getting weak.
I tested battery, replaced it, and no more SYS light.
Old May 21, 2002 | 11:46 PM
91Vette's Avatar
91Vette
The SYS blinked in my Vette when the battery was low on juice. Try giving it a charge and see if that takes care of it.
To "SYS" blinking on display???
