i just put in a brand new opti spark unit,new plugs and my wires i put in not even a couple months ago and it still bogs.when i cold start the car it is fine.when i drive its fine until i let go of the gas pedal.when i accelerate again then it starts bogging and takes forever to go into another gear.but if i floor it to try and clear it out it goes away.when i stop at a light it just sits there and bogs until the ecm richens it out.if some one can help me i will appreciate it.thanks
How is the coil? The ignition control module? What is the condition of your catalytic converter? Condition of your air filter? Any vacuum leaks?
the coil looks to be in good condition,my catalytic converters are gutted out, air filter is brand new and no vacuum leaks..the ignition control module i did not check out yet
