inter light
Old May 25, 2012 | 10:26 AM
lstark's Avatar
lstark
Cruising
Default inter light
Hi My alarm went off last night and now the inter lights won't turn off.
could the alarm relay be bad, if so were is on the car, 1994 Vette coupe
Old May 25, 2012 | 12:04 PM
lstark's Avatar
lstark
Cruising
Hi if the interior lights won't go off, could the Battery
be bad?
Old May 25, 2012 | 04:25 PM
ch@0s's Avatar
ch@0s
be bad?
If the battery were bad you would have "no" lights. I ck to make sure you didnt turn them "on" look at the dimmer. It could also be a door jam switch.
Old May 25, 2012 | 04:56 PM
dukeallen's Avatar
dukeallen
Maybe he has the clear roof and it's acting as a solar cell, charging the battery and keeping his lights on...
Old May 25, 2012 | 05:14 PM
BlackbirdZ07's Avatar
BlackbirdZ07
This problem seems to come up weekly... maybe we should make a sticky.
Hatch switch could be bad. A door switch could be bad.
First check the adjustment of the door switches. If you look at each switch, you'll see that the end of the plastic plunger (where it contacts the body) has a small round head. That can get pushed in too much over time, which can cause your problem.
Pry that head outward with a small flat blade screwdriver. That makes the plunger longer so that the switch closes all the way, turning off the lights. Don't worry about prying out too much; the first time you close the door it'll get pushed back in to just the right lenghth.
Old May 26, 2012 | 02:11 AM
Cliff Harris's Avatar
Cliff Harris
Probably a bad door switch.
The "plunger adjustment" is bogus and does nothing useful.
Old May 26, 2012 | 02:31 PM
BlackbirdZ07
Why do you say that? Sometimes the pin gets pushed in too much and you pull it back out. If that's not the problem then you're right, it won't fix anything. But it's free and it takes all of ten seconds per door, so why not try it before replacing switches that may not even be bad? It's worked for me and others.
To inter light
