Besy optis
Old Jul 19, 2012 | 04:04 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Default Besy optis
Need to buy one and am checking to see what everyone is using and if your satisfied with your purchase. Thank's.
Old Jul 19, 2012 | 04:23 PM
pearlmom's Avatar
pearlmom
we used a Petris Opti . so far so good
Old Jul 20, 2012 | 12:28 AM
kimmer's Avatar
kimmer
I am considering one from them, thanks.
Old Jul 20, 2012 | 12:34 AM
Smokeysvette's Avatar
Smokeysvette
I've been checking around too so I'll be ready when mine decides to give up the ghost. All I've heard about Petris Opti's is they're great. Not one bad thing I've heard about them yet.
Old Jul 20, 2012 | 05:15 AM
93 ragtop's Avatar
93 ragtop
what year vette? also consider replacing the water pump at the same time. FWIW I like the electric pump. It eliminates the weep hole on the waterpump.
Old Jul 20, 2012 | 09:52 AM
qws's Avatar
qws
If your vette is a 94 or before you won't be disappointed at all with Petris. I took the advice given here and am very pleased that I did. The AC Delco was price at $349 and Petris was $399. The Petris unit came with everything I needed for a very easy install. While I had it apart I changed plug wires, ignition coil, went with a brand new water pump, and naturally degreased while in there. Job in all reality will only take a day to do.
Old Jul 20, 2012 | 10:22 AM
kimmer's Avatar
kimmer
Sounds like I can't go wrong with the Petri's. Yes I will be changing the water pump and timing cover gaskets while I'm in there.
To Besy optis
