Cat Delete??
Old Sep 20, 2017 | 05:42 PM
fflumpy's Avatar
fflumpy
Default Smog pipe
i installed true dual on my 85' but for now im leaving the smog pipe.…how do you plug it? Or do u leave it open?
Old Sep 20, 2017 | 07:54 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Why bother? Leave it.
Old Sep 22, 2017 | 07:31 PM
pezter22's Avatar
pezter22
Originally Posted by Dynamo6969
http://www.corvettecentralexhaust.co...mance_dual.php
i bought the set with the LT1 Mufflers in march, the tone is great and so much happier without the cat. has a spot for the o2 sensor as well.
I bought the set up from Corvette Central for my '84. I also gutted my smog pump and had the tubes cut and welded shut on my exhaust manifolds.
After the install, I did have to bring the car to a muffler shop to bend the tail pipes. They mounted a bit too low. The shop heated and bent the pipes and tucked them so they hung correctly.
The car sounds great, no drone and no O2 sensor error codes (yet).
