Transmission
Old Aug 24, 2012 | 01:43 PM
Rooneytoons's Avatar
Rooneytoons
Default Transmission
Hi guys as you can see I'm new here and looking for advice on the auto transmission from a 1984 corvette
1st are they 4 speed ???
2nd is the tranny likely to be a 700r or 700r4 ???
3rd is anyone using a B&M shifter if so which one are you using ???
Sean from England
Old Aug 24, 2012 | 03:18 PM
cubetop's Avatar
cubetop
1) Yes
2) 700R4
3) Using the stock console so I can't help.
Old Aug 24, 2012 | 03:39 PM
Rooneytoons
Originally Posted by cubetop
1) Yes
2) 700R4
Thanks for the info I've just seen on the B&M website that the megashifter will fit the 4 speed auto box .
Is there a difference between the 700r and 700r4 transmissions do you know ???
Old Aug 24, 2012 | 03:49 PM
383vett's Avatar
383vett
Same tranny, different name.
Old Aug 24, 2012 | 03:55 PM
cubetop's Avatar
cubetop
What he said. It's the same thing, people just call it different things. Hopefully someone on the site will have used a B&M shifter and can help you further. Best of luck!
Old Aug 24, 2012 | 04:53 PM
Rooneytoons
Many thanks guys
Old Aug 25, 2012 | 06:36 PM
SQUIRMIN VERMIN 84's Avatar
SQUIRMIN VERMIN 84
From: Supreme Soviet Peace-Loving Pipple's Kollektive of Seattle Wa
Have you contacted B&M?
Try this:
http://bmracing.com/?page_id=47
Old Aug 26, 2012 | 12:03 PM
Rooneytoons
Try this:
Was looking at her website and the mega shifter will work with the tranny there's a Blocker pin that needs to be removed for the 4 speed gm transmissions
To Transmission
