door window
Old Sep 3, 2012 | 01:28 AM
jim spitzer's Avatar
jim spitzer
St. Jude Donor '12
Default door window
I get in the car today and try to put the windows down. Drivers side is fine, Passenger side will not work with either switch drivers or passenger. So it leads me to the window motor. Does that sound about right?
No more driving with the top down until thats fixed. (BUMMER)
Old Sep 3, 2012 | 01:59 AM
Dans 85's Avatar
Dans 85
I suppose so. But it could be switch or wiring too.
Simple test FYI...I've seen a few GM window motors get 'stuck' then once jarred loose they may work fine from thereon. You can try (with the car running) holding the window switch in the down position as you give the pass door a few good closes, it might just free it up if that's the problem.
Regards,
Old Sep 3, 2012 | 04:08 AM
gerardvg's Avatar
gerardvg
Had that happen the plug is sensitive and can be pulled on a angle from the rest of the loom in the door.
Old Sep 3, 2012 | 07:31 AM
jim spitzer
St. Jude Donor '12
A Big Thanks guys, I went out this morning started the car had the wife slam the door, (and believe me shes good at that) Bingo it worked. The window started working.
Thanks again
Old Sep 3, 2012 | 03:05 PM
Dans 85's Avatar
Dans 85
Just when an unwanted attribute comes in handy, glad she helped you to fix it.
You know you now owe her one for the expertise.
Old Sep 3, 2012 | 03:43 PM
jim spitzer
St. Jude Donor '12
Yes I will take good care of my wife. She will help with any part of the repair.
Old Sep 3, 2012 | 07:49 PM
pjgiantsfan's Avatar
pjgiantsfan
I just had this problem with my 1993 coupe. If I close the passenger window with the door open, it seems to go up a smidge to far and jams the regulator or motor. If I push down lightly on the window it frees the gear. Now I only close the window when the door is closed. I am sure there is an adjustment but I wll wait until I do weatherstrips
Old Jun 29, 2019 | 09:32 PM
thatsanicepicture's Avatar
thatsanicepicture
3rd Gear
I came up to the forum tonight to see what size the rivets are for the regulator motor and saw the thread.
OMG! Slam the door? Really? I worked! Yes it worked.
Thank you. Thank you. Thank you.
To door window
