dual mass flywheel
Old Sep 28, 2012 | 07:02 PM
kennedy5150's Avatar
kennedy5150
Cruising
Default dual mass flywheel
Looking for a dual mass flywheel for a 1995 corvette LT1
Old Sep 28, 2012 | 09:24 PM
MyOtherCar's Avatar
MyOtherCar
Veteran: Marine Corps
ain't none
well, at least what I have found out/searched for/heard about.
apparently the mfg'er stopped producing them and no other company has stepped in to produce.
but, let us all know what you find out in today's world as you search
Old Sep 28, 2012 | 11:22 PM
Blue95C4's Avatar
Blue95C4
My local Corvette Shop talked me into going with a single mass flywheel. To get it quiet again, I'm going to have to try a Tremec.
In first or second, the ZF sounds like it's gonna fall out of the car.
In neutral, the tranny is louder than the exaust and I have straight through mufflers.
Old Sep 29, 2012 | 12:09 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
I believe Bill @ ZFDoc has a fix for that but requires the unit to do the procedure. No idea how expensive. The procedure has something to do with bearing tolerance....I think.
I will say blue-printed units from Bill are reported to be (even more) bulletproof than the already sturdy ZF6.
To the OP:
I noticed PowerTorqueSystems has resurfaced DMFs on their website -- though I've yet to read of anyone here using one. No idea if there's really any availability either.
From time-to-time, I have seen one/two resurfaced units posted around.
Old Sep 29, 2012 | 07:08 AM
Blue95C4's Avatar
Blue95C4
As a stop-gap, it was suggested to try a thicker tranny fluid. I may give that a try but I will call ZFDoc first. Thanks !!
Old Sep 29, 2012 | 10:21 AM
anciano's Avatar
anciano
Hmmm...being more of a motorcycle guy I had never heard of a dual-mass flywheel, and had to look it up. It seems strange that GM engineers went to this Rube Goldbergian contraption instead of an electronic limiter on the engine's torque output to keep stress on driveline components within limits. I can't imagine that an algorithm involving torque/rpm/traction would be too difficult for the CPU to handle.
Of course I'm not hampered by a knowledge of the subject. Which means my qualifications as an instant interwebs expert are perfectly in order.
Old Sep 29, 2012 | 11:38 AM
SJW's Avatar
SJW
The problem isn't caused by engine torque, per se. The problem is caused by the shallow helical angle of the gears in the ZF box. Low-RPM combustion impulses (especially at idle) cause nasty gear-rattle in the ZF box. GM was able to solve this problem with the dual-mass flywheel, which damps the impulses before they reach the ZF's input shaft. Installing a single-mass flywheel, especially one with a low mass, couples these impulses straight through to the input shaft, and the resultant gear rattle is exactly what the DM was employed to eliminate.
FWIW, I installed an extra-mass billet steel flywheel from Spec, along with a Spec stage 2 sprung-hub clutch kit in my '94, and have only minimal gear rattle. I can only hear it when the windows and ragtop are up, and nobody else has even noticed or commented on it. In this car, it's only barely audible over the Corsa exhaust. The fact that the blue-tag ZF in my car, with its slightly steeper helical angles, is somewhat less prone to this problem probably helped a bit in my case. Different gear oils might also affect the results.
Live well,
SJW
Old Sep 29, 2012 | 12:14 PM
anciano's Avatar
anciano
I stand enlightened, SJW, thanks.
Old Sep 29, 2012 | 12:47 PM
SJW's Avatar
SJW
You're welcome. Enlightenment is good, and a big reason this forum exists. Glad I could help.
Live well,
SJW
Old Sep 29, 2012 | 01:33 PM
Blue95C4's Avatar
Blue95C4
Several of the German Luxury cars were equipped with Dual Mass Flywheels.. Mercedes-Benz, BMW, Porsche, and Audi.
I spent $2000 for a single mass including preasure plate and install and I am dissapointed with the rattle.
ebay has a new GM DM for $700.
I wish I had gone that route.
http://www.ebay.com/itm/90-91-92-93-...f936a2&vxp=mtr
Its hard to imagine that GM picked a tranny that required a "fix" before it could be used.
Old Sep 29, 2012 | 02:49 PM
cv67's Avatar
cv67
St. Jude Donor '05
Its a performance car its gonna make some kind of noise;plus its practically sitting right in your lap lol.
If Gm didnt build strength into these but were whisper quiet then people would complain they break all the time. Ugh.
Ive driven a number of C4s with the aluminum flywheel and hated it every time.
Old Sep 29, 2012 | 08:30 PM
slickfx3's Avatar
slickfx3
That's what my engine installer says, but the rattling wears on you, it's a different kind of annoyance, like water-boarding, you know ya ain't gonna die, but, it sure is uncomfortable.
That said there's plenty of faster cars that don't rattle; since they don't make the dual mass anymore, the noise is here to stay, spec put out a 28 lb single mass a year ago, the 22lb steel one didn't help, god be with you on the aluminum
Old Sep 29, 2012 | 11:30 PM
GREGGPENN's Avatar
GREGGPENN
http://www.ebay.com/itm/90-91-92-93-94-95-C4-CORVETTE-ZR1-LT5-DUAL-MASS-FLYWHEEL-NEW-GM-10174481-ZR-1-/221039376034?pt=Motors_Car_Truck_Parts_A ccessories&hash=item3376f936a2&vxp=mtr
The link is for a ZR1 car....it's different.
GM picked the ZF because it was THE ONLY 6-spd available at the time of the C4 ZR1 inception. It was their only option if they wanted to fit the ZR1 with a 6 speed -- unless they wanted to delay production at least another year.
Getting into a stick C4 (or even auto) can be disappointing the first time. Some people consider it the halo of GM cars and expect perfection. It's not a Caddy, it's a car built for performance, break-thru aerodynamics, and even performance/emissions (for that era).
Old Sep 30, 2012 | 10:43 AM
anciano's Avatar
anciano
Which raises another (non-DM flywheel) question: exactly what target was GM aiming at with the C4 Corvette? It's not really a sports car in the traditional, stripped-down-for-performance sense since it has a lot of Cadillac-style amenities and features; but at the same time the harsh ride and contort-to-enter ergos fall short of luxury accommodations.
Is it the first hybrid? Instead of Corvette (a small warship!) maybe GM should have named it the Chimera -- half human and half beast.
To dual mass flywheel
