Sys light
Old Sep 30, 2012 | 11:49 AM
enventr's Avatar
enventr
Default Sys light
On my 95 ,today I noticed a sys blinking light going on .it flashed 3 times then it goes back to reading the correct voltage or water temp.this happens every few minutes.The owners book said it could be electrical.could this also be a "security" light problem.the gauge in the car said it is charging correcting.this car is driven about once a week.Does anyone have any ideas what could be causing this? thank you
Old Sep 30, 2012 | 12:51 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
The number one cause of a flashing SYS light as you describe, is a low battery.
I don't think it has anything to do with security.
As you noted in the manual, it indicates an electrical issue.
Even if your charging system is working correctly, the battery could still be on its last leg.
Have the battery load tested and find out.
How old is your battery?
If you only drive the car once a week, do you use a battery tender when not in use?
A new battery solved this issue in my '96
Old Sep 30, 2012 | 01:46 PM
94z07fx3's Avatar
94z07fx3
Post codes by module for more help. I do agree with Rolla that low battery is most likely. But why not check the codes?
http://forums.corvetteforum.com/c4-t...n-96-cars.html
Old Sep 30, 2012 | 02:19 PM
nathanours's Avatar
nathanours
Mine was doing the same and when I checked it it was throwing all sorts of codes. Changing the battery fixed everything. It's free to have it checked at autozone.
Old Sep 30, 2012 | 03:43 PM
Frizlefrak's Avatar
Frizlefrak
Go ahead and pull codes, but odds are, battery is sending out a distress signal.
Old Sep 30, 2012 | 05:39 PM
enventr's Avatar
enventr
Thanks guys I will check tHe, battery this weekend,.the battery is around 3 years old and I never used a battery tender.i use the car approx one hour each weekend
Old Oct 1, 2012 | 12:56 PM
96 Vette CE's Avatar
96 Vette CE
Banned Loser
From: They say you learn from your mistakes, I must be a genius
2017 Corvette of the Year
2016 C4 of Year Finalist
Creator of the "Original" whining and crying thread
St. Jude Donor '14-'15-'16-'17
Seeing where the car gets used very little you would be wise to invest in a quality battery tender, if not, this probably won't be the last time you run into this problem.
Old Oct 6, 2012 | 07:40 PM
enventr's Avatar
enventr
Battery was weak.i started the car after using it last Sunday and light was off.i had taken it to my mechanic and he said it was a weak battery.if it does not charge up I will replace it.thanks to all for the advice.
To Sys light
