Can't Stop
The miles just keep piling up.
It will be even nicer when the temps around come down to less than 100 degrees. At least it's cooler at the beach!
Bought with body damage, Charcoal Metallic paint & clearcoat was trashed on majority of vehicle.
Non maintanence repairs performed @ how many miles.
174,000- Top end rebuild for blown head gasket.
port/polish heads new valve springs/ 1.6 rockers/ radiator/ hoses/ WP/t-stat/ coolant temp sensor
175,000- R & R fuel pump/ fuel regulator/ egr valve/ ignition module/ fuel filter
177,000- R&R Aip pump & hoses
(I live in CA)180,000- front end rebuild
new steering rack/ ps pump/ hoses/ bushings
181,000- new brake booster/ master cylinder
185,000- trans rebuild
new flywheel/ starter/ torque convertor/ shift kit / DS U-joints
190,000- Primary cooling fan
194,000- R&R U-joints in half-shafts
196,000 R&R TPS
197,000- new bulbs in cluster
- I've got about another 197,000 to go...
