Electrical schhematic
Old Oct 13, 2012 | 08:55 AM
Wiltsiemike's Avatar
Wiltsiemike
7th Gear
Default Electrical schhematic
I need an electrical schematic for the drivers seat controls for a 1984.
I just replaced the seats with ones from a 96 and nothing works.
Mike
Old Oct 13, 2012 | 07:54 PM
rodj's Avatar
rodj
Originally Posted by Wiltsiemike
nothing works.
You would need the circuit diagrams for both years to do a match up ,
IIRC the later ones are wired different
Old Oct 13, 2012 | 10:59 PM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
3 or 4 years ago I replaced my 84 drivers seat track with one from a later year.. IIRC there were only the two styles, 84 to i believe early 87 and later 87 to 96.. the early ones had round pins in the connector while the later one had flat pins.. Fortunately the replacement came with the female so I just cut my female off and used the one that came with the replacement..
Old Oct 14, 2012 | 07:51 AM
Wiltsiemike
7th Gear
I have already replaced the plug at the seat base ....the wire colors match up and I used the old seat plug and put in new pins ... what I need is the schematic for the wiring to the seat control switches for the 84 vette.
Old Oct 14, 2012 | 09:24 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
This is from my 86 FSM, not 100% sure it's correct for 84, but chances are very good.
http://members.shaw.ca/agent86/Power%20Seats.pdf
Old Oct 14, 2012 | 11:11 AM
ccrazor's Avatar
ccrazor
Wiring for the 84 is the same.. The only difference is in the layout, the 84 FSM shows the control as a block with front control, center control and rear control..
Old Oct 15, 2012 | 05:17 PM
Wiltsiemike
7th Gear
Thanks alot ... thats what I needed ...now the seats work properly .
To Electrical schhematic
