lovin' the new engine!
Interestingly when I pulled the old y-pipe off I found that the rear cat had been gutted. The front cats appeared to be good - we cut off the inlet pipes just to check them out.
The really odd thing was the weight of the old converter. I didn't have a scale to put it on but I swear it was well over 100 pounds. When I pulled it off the trans I had to drop it on the floor. It was too heavy to try to lift up over the fender and there was no place to set it anyways. The replacement converter was around 40 pounds as I would expect for a 12" unit. I took the old one over to O'Reilly's to dump with their metal recycling and even the young guy who works there was amazed at how heavy it was. The first time he went to lift it, he almost fell forward.
I think the lighter converter is a big part of the responsiveness and I'm sure the extra stall speed helps too
For those that are late to the party, my combo is:
87 short block w/64k miles
Scoggin-Dickey LT-4 repro cam .480 lift 204/211 @ .050 on 115 separation - used an Edelbrock timing set and installed it at 0 degrees
GM Fast Burn heads
Accel high-flow base (welded up to seal the FB port size), matching runners, ported plenum, 58mm tb
LT-1 manifolds
Magnaflow catted y-pipe and new center cat
Flowmasters
March under drive pulleys
Bosch III 23# injectors
Holley AFPR
converter from Price's Garage - stock rebuilt unit for a 97 Vortec V-6 S-10
Once the tune is in I'm going to do something about my trans. I think I'm going to need to replace it but I ran out of time doing the engine replacement and had to get it back on the road or I'd have done it at the same time.
Can't wait to get the tune in there so I can see how it really feels all the way through first and second
When I got my tranny From the frieght delivery I lifted the Tranny and the convert of the truck by myself.
When I took the Converter off my bad tranny it was also heavier than the stock converter that came with the tranny I bought.
When you installed the new converter You filled it with fluid right?
The 91 IS my DD
They'll warranty it with my new converter, 36yr/100k and even install my shift kit. If it blows up they'll replace it - parts and labor included. If that happens, I'll buy another one of these converters since it was cheap anyways.
Not sure how they figure it out, but then again how do any of the mail-order tuners figure it out?
Turns out the code is h32 due to my temporarily missing EGR feed.
