C4 head lights
Old Feb 14, 2013 | 09:05 PM
aboatguy's Avatar
aboatguy
Default C4 head lights
I was driving back from New Orleans tonight and it hit me.
Even with the new silverstars my headlights are FEEBLE wWhat sucks worse than stock C4 headlights?
So things that suck worse than C4 headlights.....
Old Feb 14, 2013 | 09:08 PM
aboatguy's Avatar
aboatguy
and I'll go first
Being the owner of the red with black roof C6 vert thats broken on the side of the I10
Red Dot by overpass is a nice looking c6 vert sitting all alone on the shoulder..
It was a beautiful looking car. But I know that being on the side of the road sucks worse than C4 headlights.
According to all the threads in the C6 section Z06 exhaust valves may actually be worse than C4 headlights
Hopefully its wasn't this C6 issue
Old Feb 14, 2013 | 10:09 PM
93Rubie's Avatar
93Rubie
I switched from stock to Hella glass with normal H4 bulbs. Huge difference and very pleased. I had some Silverstars in them before. They did not last long and marginally brighter. Get the Hella glass units=big difference over stock reflectors.
Old Feb 14, 2013 | 10:17 PM
shakedown067's Avatar
shakedown067
St. Jude Donor '12-'13
Soooooooo looking forward to switching to fixed headlights!
Old Feb 14, 2013 | 10:57 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
How bout this poor C4 owner. Saw this car in West Palm Beach, FL. A lizard or a gecko ran out from under the cover when I walked up to take the pic.
Old Feb 14, 2013 | 11:09 PM
vetteoz's Avatar
vetteoz
http://www.rallylights.com/Hella_200...Headlamps.aspx
Old Feb 15, 2013 | 05:40 AM
gerardvg's Avatar
gerardvg
Standard sealed beams are shocking, but you can easily fit the H4 lights and then can fit a large selection of H4 globes in varying watts.
I have since upgraded to the HID hi/lo type that fit the Hella H4's
they are 55 watt 4,300k. You can get them in 4,300k white 6,000k diamond white or 8,000k blue tint colors in 35 or 55 watt range.
They are around 300x brighter then H4 and cheap
The correct use of HID lights are in projector light assemblies, but the h4 hi/lo light conversion has a metal shroud around the globe that concentrates the light output to work with the original H4 lenses. That way you do not blind other drivers, if your headlights are aimed correctly.
When driving at night it is obvious who has HID lights as they are so much brighter and make even H4 lights look yellowish and pale.
Old Feb 15, 2013 | 08:28 AM
Goldcylon's Avatar
Goldcylon
Had SilverStars, Had Hella H4 housing with brighter blubs. Still was not happy... So I went to HID projector housings. Finally Happy.
Old Feb 15, 2013 | 08:33 AM
kimmer's Avatar
kimmer
C4 of the Year Finalist
That's one beautiful Z.
Old Feb 15, 2013 | 09:02 AM
Goldcylon's Avatar
Goldcylon
Old Feb 15, 2013 | 06:04 PM
C4 King's Avatar
C4 King
If you want to sell your plastic Wagner lights, let me know.
Old Feb 16, 2013 | 03:12 AM
KentsOkay's Avatar
KentsOkay
What Silver Star bulbs are y'all buying? Ultras? Model #?
Old Feb 16, 2013 | 12:12 PM
Jbws86928's Avatar
Jbws86928
St. Jude Donor '13
Old Feb 17, 2013 | 05:54 AM
Bandit1977's Avatar
Bandit1977
Gerardvg,
Where did you source the Hella H4 headlights in Australia?
I drove my C4 for the first time yesterday morning to work before the sun came up. I was shocked at how bad the stock headlights are.........maybe I'm just used to the lights on my FG XR6 daily driver?
I actually think the original 7 inch sealed beam headlights on my 1971 Firebird might be better than the Vette..
If you change over to H4's do they draw more current and therefore require changes to the wiring and/or relays?
I reckon I need to try what you've done with your lights.
Thanks,
Ken D
Old Feb 17, 2013 | 07:58 PM
gerardvg's Avatar
gerardvg
Originally Posted by Bandit1977
Gerardvg,
Thanks,
Ken D
Hi Ken
The rectangular headlights the vette uses are a common size, i purchased the Hella H4 ones as they were the glass type some 10 or more years ago.
The plastic type will loose shape with high wattage lights, with H4 lights you can use the standard wattage 55/65 H4 globes.
Or go with 90 watt low beam 130 watt high (what Police cars use), and 100w low 140w high H4 globes. Now they were really good but the HID 55 watt ones are 300 times brighter, and they do not have the filaments that tend to break when closing the headlight doors without allowing the globes to cool down. HID doesn't get affected by this HOWEVER HID upgrades are not legal mainly due to people who do not fit them correctly use the blue color range or align the lights.
In Australia you are only allowed to use the white lights, anything that can be looked at being emergency vehicle lights will get you a ticket. So go to the H4 first and later you can always get a HID hi/lo conversion kit.
The current is not a problem as the corvettes already have the relays for the lights in the engine bay.
The parts shops tend to have the cheap plastic lights nowadays, so you may need to look for the good glass type at a 4x4 off road shop.
I think you need the 7'' x 5'' (200mm x 142mm) that is just a guess so measure your lights first.
The 55w HID hi/lo conversion kit that will connect into your H4 type lights are around $60-$80 here in Australia complete with ballasts wire harness and 4,300k (white)or 6,000k (diamond white) or 8,000k (blue) range lights i used the 4,300k ones.
Remember you need Australian lights for r/h drive the internal reflectors are different for l/h drive cars. Also cheap lights may not have good reflectors and not as bright even with the high wattage H4 lamps.
Cheers
Gerard
Old Feb 17, 2013 | 08:17 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
I've always been amazed how the front of a C4 with the lights up looks like one of those cartoon "Chevron Cars"
Actually it's kinda weird looking
Not like those "later" C4's
Originally Posted by corvetteronw
Old Feb 17, 2013 | 08:22 PM
Chewch87's Avatar
Chewch87
WHAT DID I EVER DO TO DESERVE THIS?????
To C4 head lights
Old Feb 17, 2013 | 11:36 PM
Cliff Harris's Avatar
Cliff Harris
I've had Silverstars on my '86 for years. I thought they were OK until I saw the headlights on my C6.
NOW I UNDERSTAND why everybody is nutso over the HIDs. YOU NEED THESE!!!!
I looked into HIDs for the '86 several years ago and they were at least $500 at the time. I didn't think it was worth that much. Now they are a lot cheaper, so it's time to reconsider.
Old Apr 10, 2013 | 10:04 PM
speedycat3's Avatar
speedycat3
I recently got these new headlights and I love them every time I drive at night.
Nice alternative to HID's. A bit on the pricy side but can be had for less if you look.
Old Apr 10, 2013 | 10:11 PM
mikeb's Avatar
mikeb
2023 Corvette of the Year Finalist - Unmodified
2022 C3 of the Year Winner - Unmodified
Did you go visit Red?
Was there a black #3 on the rear window?
