I am told these wheels came from a 40th anniversary. They are the unpainted sawblades with the flat machined face. They he clear coat which is now peeling.
I think they are aluminum, but I am not 100% sure. Maybe magnesium??
Anyway, I am cleaning them right now to get all the gunk off, and plan to use aircraft remover to remove the remaining clearcoat, before re-shooting them with clear again.
Just wanting to know of others who have done this and be certain that the aircraft remover is not going to damage/discoloration the metal.
Not likely what you wanted to hear but this is a wheel that if they're in good cosmetic condition with the clear peeling or otherwise damaged you would be better off having them refinished/reconditioned professionally. Your wheels are aluminum which generally requires an adhesion promoter, proper preparation and cure for satisfactory results.
If you go after the machined finish with sandpaper, scuff pads and the like you'll ruin the machined finish.
I'd check locally for some wheel repair/restoration facilities and see what the options are. Materials for a proper refinish aren't inexpensive and you likely won't be happy with the results.
If you're dead set on doing them yourself spend considerable time doing the research.
Alodine is I believe a good adhesion promoter or a good beginning read regarding conversion coatings and adhesion promoters for aluminum refinish.
I am in an auto refinishing class. I have all the professional tools. I already refinished the rest of the car, my truck, and countless others. I've done other wheels, but not aluminium. Just doing some research ahead of time. Thanks for the tip on the adhesion promoter.
There you go! The "rest of the story"! It could be an interesting project and check with whatever "supplier" of your reinish supplies could be for promoters and stuff. Your choice of the clear here is a bit more critical than that on just a color/clear refinish of a painted top surface.
I went to my normal auto paint/supplies shop who also had a shop. They gave me the Matrix brand clear that they use on all of their wheel refinishing projects. They didn't mention the promoter, but from what I read on sem's website, it's good to use but not an absolute must. But since it should help prevent peeling etc... I'll use it.
Right. Think of the chemicals those wheels are exposed to, both from road exposure and from cleaning and detailing. can't wait to see the finished product!
I refinished two sets using the aircraft paint stripper, then followed up with some light polishing. Average about an hour per wheel total. Main thing to watch is the aircraft stripper also destroys rubber. So remove the tires and valve stems first.
Yep, no tires, but I will remove the valve stems before I start. Need them off before I paint anyway.
Just finished buffing out one of the stripped wheels. (Picture will be posted later today) it looks incredible. Almost a shame to re-clear them. Debating on leaving them bare. They will shine more that way.
