headliner sagging
Old Jun 18, 2002 | 09:00 PM
paulvitiello's Avatar
paulvitiello
Default headliner sagging
any suggestions on how to fix a sightly sagging without taking it all apart
Old Jun 18, 2002 | 09:10 PM
carter200's Avatar
carter200
Default Re: headliner sagging (paulvitiello)
One trick is to use a syringe full of super glue :yesnod:
Old Jun 18, 2002 | 09:13 PM
paulvitiello
Default Re: headliner sagging (carter200)
i thought about that but i want to make sure t dont make a bigger mess than it might worth
Old Jun 18, 2002 | 09:29 PM
carter200's Avatar
carter200
Take it to a detail shop and ask them. :yesnod:
Old Jun 18, 2002 | 09:45 PM
paulvitiello
i think that is what i will do thanks for the help
Old Jun 18, 2002 | 11:38 PM
SLEV89's Avatar
SLEV89
i've done this on other vehicles and have learnt that it's pretty much best to virtually remove the entire headliner, or at least detach it enough so that access to the entire back surface is available (unless the rest is holding well).
then one uses a good spray-on adhesive over the entire area, both fabric and ceiling, and then work the fabric back into place.
some advice from a pro would never be a waste of time though!
Old Jun 19, 2002 | 01:31 AM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
I dropped off my top at a headliner shop at 10a.m. and picked it up at 3p.m. brand new...$50 tax included and no headaches...good luck
Old Jun 19, 2002 | 01:38 AM
GRNVNM93's Avatar
GRNVNM93
Default Re: headliner sagging (golfboy1)
I paid $90 to have the headliner and sunvisors redone, looks excellent and didn't give me any headaches!!! :cheers:
Old Jun 19, 2002 | 07:57 AM
JonM's Avatar
JonM
Look here ..
http://forums.corvetteforum.com/zerothread?id=300880
To headliner sagging
