Help! "Thumping" noise
...WW
There's no point of buying the same rotors and just warping them again at the next event. I'll probably order one of those air duct kits too, a guy there had one on his C4. Certainly couldn't hurt to have some air flowing through there.
Nope, tires look good! Well, as good as Sumitomos can be
I just used the jack, it held up. I need to get one of those
So it appears to be warped rotors. I plan on continuing to autox, so I think I should upgrade. Research begins now. Any suggestions?
Edit: no arguing allowed, only brake advice, thanks!
The brakes do get hot, a couple tips. Don't sit with the brake on in the staging lanes between runs. If you have to, do it very lightly, and let the car roll forward a little once in a while, every minute or so.
If your between heats,I usually just shut the car off, and leave it in gear. NEVER set the parking brake with hot rotors.
Over torquing the wheel nuts can cause brake rotor warpage as well. 100ft-lbs and no more.
You don't need the cross drilled and/or slotted BS to run auto-x. Or even HPDE or track events. Many a race car run just plain vented cast iron rotors.
Heck, for auto-x you don't even need the Hawk and whatever pads. The brakes just don't get super hot at a typical auto-x. Good pads are a much for track use and don't hurt for auto-x but you don't NEED them.
Ditto on the brakes cooling for auto-x, you really don't need it.
Warped brakes come from: Too hot then sit with parking brake/brakes on.
Over torqued wheels
Too much lateral runout in hub
Too much lateral runout in rotor
Too much thickness variation in rotor
Brake pad deposit build up on rotor see above about thickness variation.
OP, Your calipers aren't hanging up, b/c you could turn the wheel when you jacked it up. Still flushing brake fluid is good PM and should be done annually.
If you're looking to upgrade, look for well priced, take-off sets from newer cars, like the C5. We don't know you budget, but I did a C5 upgrade for <$500. I got rotors, calipers, brakets, the adapters, HP+ pads and it made a huge improvement. For <$500, it was a smokin' deal.
The alternative is to buy the CHEAPEST rotors you can get, and treat them like disposable items.
Honestly, I can't believe that you warped rotors in auto-x. Are they worn really thin? Were you "two-footing" it?
Over torqued wheels
Also, I checked the torque on the lugs, seemed to be about 100.
