95 engine trouble
Old Apr 4, 2013 | 09:31 PM
esmithproject's Avatar
esmithproject
3rd Gear
Default 95 engine trouble
1) My LT1 1995 6 speed manual trans started getting hard to crank a few days ago. The starter would turn over a long time before the engine fired.
2) Then the other day I started it up and the engine ran for about 5-10 seconds and shut off. It would fire up again and run a few seconds and shut off.
3) If I tried to give it gas it would die instantly.
Any ideas about what could be causing this kind of trouble?
Does this sound like a fuel issue or an electrical issue?
Old Apr 4, 2013 | 10:17 PM
Smokeysvette's Avatar
Smokeysvette
Have you done a fuel pressure test yet? Any codes?
Old Apr 4, 2013 | 10:22 PM
esmithproject
3rd Gear
No, could it be the fuel pump or a clogged filter?
Old Apr 4, 2013 | 10:47 PM
Frizlefrak's Avatar
Frizlefrak
Well, it could....and it could be a hundred other things. Would you like to troubleshoot, or go on a guess-a-thon?
Test fuel pressure during an event and report back with the results. We'll go from there.
Old Apr 4, 2013 | 11:19 PM
esmithproject
3rd Gear
Just forget it.
Old Apr 4, 2013 | 11:24 PM
DinoBob's Avatar
DinoBob
Hate to say it but Frizlefrak is right. Too often, lack of info leads both owner and forumites on a wild goose chase that costs the owner too much money and frustrates people who are actually trying to help. If you must, change the filter first, since it is cheap and a maintenance item. Then, check the fuel pump pressure.
Old Apr 4, 2013 | 11:38 PM
John A. Marker's Avatar
John A. Marker
It sounds like fuel issue. with Frizlefrak...you need to start by testing the fuel pressure. That will tell you if it is a fuel issue. If you don't have a fuel pressure gauge, many of the auto parts stores will lend you one. If it is a fuel issue, we can then direct you into additional testing to pin point the most likely solution.
You asked for help....we are leading you in the correct direction.
Old Apr 5, 2013 | 12:43 AM
Kmcoldcars's Avatar
Kmcoldcars
You asked for help in locating the problem, got useful advice and did not like what you heard. What else would you like us to do on the forum, use our Great Karnak powers and figure out the problem by magic? YOU will have to do the work and forum members will supply useful ideas.
Old Apr 6, 2013 | 12:02 AM
mtwoolford's Avatar
mtwoolford
I'm willing to bet that fuel filter's been in there a long time. It's a maintenance item that should be replaced regularily but probably hasn't..So go ahead an replace it; it might be it. good luck
Old Apr 6, 2013 | 12:16 AM
vettething's Avatar
vettething
Cruising
Just forget it.
lol.. don't get upset.. but im guessing fuel pump.
Old Apr 6, 2013 | 12:31 AM
aboatguy's Avatar
aboatguy
Yes, but as others said, it could be other things too. Simple things like a bad FPR,
Fuel pressure test on a 95 is simple.
MIke
Old Apr 6, 2013 | 01:40 AM
Frizlefrak's Avatar
Frizlefrak
Just forget it.
Dude....dial back the butt hurt and we'll help you fix your car. It's what we do. You've got, at your disposal, a wealth of knowledge here, and we love solving a good mystery....but if you're just gonna waste our time guessing at it, we can move on to the next issue.
Smokeysvette asked you the first question in a logical sequence of troubleshooting. I reiterated his point. You car may not be running correctly, but the BHOM is working fine.....
Old Apr 6, 2013 | 02:55 AM
SQUIRMIN VERMIN 84's Avatar
SQUIRMIN VERMIN 84
From: Supreme Soviet Peace-Loving Pipple's Kollektive of Seattle Wa
Mmmmmm, the Butt Hurt is strong in this one...
Old Apr 6, 2013 | 09:53 AM
aboatguy's Avatar
aboatguy
Awesome
Old Apr 6, 2013 | 11:00 AM
lt4obsesses's Avatar
lt4obsesses
Just forget it.
Famous last words before spending $1,500 replacing everything but the part that isn't working. Oh well, keeps the autoparts industry running.
Old Apr 6, 2013 | 01:19 PM
Frizlefrak's Avatar
Frizlefrak
Someone has to stimulate the economy.
Old Apr 6, 2013 | 01:42 PM
desertmike1's Avatar
desertmike1
Just forget it.
OK..
Old Apr 7, 2013 | 09:21 PM
NuckinFutz93's Avatar
NuckinFutz93
I came through Mineral Bluff today, I think it messed with alot of peoples heads. People were waving like crazy, then saw my face and gave me the WTF are you look. I came down 60 spur and went north to Copperhill/McCaysville.
To 95 engine trouble
