HELP 88 corvette
Old Apr 7, 2013 | 05:40 PM
robert007's Avatar
robert007
Default HELP 88 corvette
Yesterday I took out my C-4 for a ride for the first time this year. I smelled anti freeze for the entire ride. Today i went out to the car and noticed that floor on the passenger side was wet and smelled of anit freeze. Then i ran the car and noticed a sort of steam coming out of the heater on the passanger site. Does anyone know what it could be and is it expensive to get fixed?
Old Apr 7, 2013 | 05:50 PM
True Mountaneer's Avatar
True Mountaneer
HEATER CORE,for now you can bypass the core by hooking both nipples of the water pump together with a single hose,It will be alright till you need heat,or fast defrosting.
Old Apr 7, 2013 | 05:52 PM
DinoBob's Avatar
DinoBob
The heater core is leaking. Do a search on the forum for "heater core" and "fastguy" as keywords. If you are a wrench, start doing some yoga stretches for the work. If you are not, it's gonna cost some $$$. Print fastguys method and take it to the mechanic. The part is no more than $75.
Old Apr 7, 2013 | 06:55 PM
TommyFox's Avatar
TommyFox
This^^^^ So glad this will never happen to me.
Old Apr 7, 2013 | 08:27 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
I have pinned the water control valve open on mine.
This way the water doesn't stagnate in the heater core.
Old Apr 7, 2013 | 09:07 PM
TommyFox's Avatar
TommyFox
This will never happen to me because I don't use crap water based coolant.
To HELP 88 corvette
