power steering pump leak
Old Apr 9, 2013 | 08:44 PM
comanchepilot's Avatar
comanchepilot
Cruising
Default power steering pump leak
Help,my return line out of the power steering pump has a leak.Does anyone know how to go about resealing the metal tube that goes into the pump?1995 c4.thanks for the help.
Old Apr 10, 2013 | 02:28 AM
Cliff Harris's Avatar
Cliff Harris
I don't know about your year, but the early power steering hoses have an O-ring on the metal fitting that can get damaged. I just bought one for about $8 at the dealer. The description says "high temperature", so your standard auto parts store O-ring may not work.
I had a power steering hose leak where the metal part was swaged onto the rubber part. The only fix in that case is to replace it.
Old Apr 10, 2013 | 07:29 AM
davewhtt's Avatar
davewhtt
I just went through that i my 93 and replaced the pump.Im sure you could seal it some how but all the trouble to get at it and clean it so a sealer would stick? On my 93 it looks like it is pressed into the pump with some kind of epoxy. Dave
To power steering pump leak
