crossfire ac delete
Old Apr 24, 2013 | 02:12 PM
ETRBUJ1984's Avatar
ETRBUJ1984
Default crossfire ac delete
Ive been thinking about this project for a long time but wouldnt mind even the compressor coming out. is it possible for an 84 to swap its ac compressor brackets to an 85? And at that point can u use the 85 pully to delete your ac? has anyone done this with there 84?
Old Apr 24, 2013 | 06:48 PM
vetteoz's Avatar
vetteoz
Easier to delete the bracket altogether and use a shorter belt
http://forums.corvetteforum.com/c4-g...empo-belt.html
Old Apr 25, 2013 | 04:05 PM
wilcar's Avatar
wilcar
I used a doman 34157 ac delete kit and a a goodyear 4060872 belt. I tried the shorter belt with no delete kit but the belt ran on the pulley lip too much so I kept the 34157 kit on. Cost is about $30 from amazon. The belt I used is for the standard factory pulleys plus the pulley on the 34157. I had to file just a little area where the pulley was rubbing on the factory bracket, about a minute job .
Old Apr 26, 2013 | 10:06 AM
ETRBUJ1984's Avatar
ETRBUJ1984
the dorman part is for an 85 and i dont think that it would fit my 84. Is that what u used it on? think ill try removing both the smog and ac with the smaller belt. When doing this i understand u just tuck most the connections and zip tie out of the way but is there anything to do with mass air flow i think that there are some small tubes that have been re position near my air pump.
Old Apr 27, 2013 | 08:51 PM
wilcar's Avatar
wilcar
The 34157 dorman is NOT for an 85 and will not fit it. It is actually for a 88-92 F body but will fit on your 84.
Old Apr 27, 2013 | 11:22 PM
My1991's Avatar
My1991
You can run a 85-87 a/c compressor bracket with 84 drivers side stuff and it will lineup perfectly. Then just buy a R4 compressor delete idler.
Old Apr 28, 2013 | 01:09 AM
vetteoz's Avatar
vetteoz
Why go to the trouble of installing later model parts so you can then buy a "delete" pulley when you can do away with everything
on the pass side as was done in the link I posted above?
Old Apr 28, 2013 | 01:38 PM
WGlen C4's Avatar
WGlen C4
I want to get rid of the A/C and Air pump on my '91 also. good luck, I don't find a lot of info on the A/c side.
Old Apr 28, 2013 | 09:02 PM
vetteoz's Avatar
vetteoz
Originally Posted by WGlen C4
get rid of the A/C on my '91 .
Look harder
http://forums.corvetteforum.com/1565351608-post6.html
http://forums.corvetteforum.com/1566807620-post48.html
http://forums.corvetteforum.com/1569586370-post53.html
http://forums.corvetteforum.com/1565366997-post17.html
To crossfire ac delete
