Locking wheel nut
Old Apr 27, 2013 | 04:50 PM
lavery48's Avatar
lavery48
Default Locking wheel nut
Anyone have a "trick to getting a locking wheel nut off ? I bought a wrecked 95 and it didn't have the tool to take the nut off with.
Old Apr 27, 2013 | 05:01 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
I took all 8 safety nuts off; bad guys are fully equipped to accomplish their goals.
Old Apr 27, 2013 | 05:02 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
Any tire shop should be able to take if off for you.
Old Apr 27, 2013 | 05:40 PM
lavery48's Avatar
lavery48
Goood Idea PLRX.....Thanks !
lavery48's Avatar
lavery48
92 Ragtop, it's wrecked, can't drive it to the tire shop.
Old Apr 27, 2013 | 06:58 PM
WVZR-1's Avatar
WVZR-1
There's many methods all have various levels of success but that can often be the operator of the devices. Why don't you put a snapshot of the style that is on the car - there's methods for the various that work better than others.
This shouldn't be a problem like the "tire shop" - you take the camera to the car!!
Old Apr 27, 2013 | 09:16 PM
65GGvert's Avatar
65GGvert
Take the locking nut off and take it to the tire shop and see if they can match it up.
Just kidding, it looks like the socket shown by PLRX should do it.
Old Apr 27, 2013 | 10:13 PM
Kmcoldcars's Avatar
Kmcoldcars
Take a 1/2 inch drive socket that is just a tad too small to fit and drive in on the locking nut with a big hammer. Then insert a breaker bar into the socket and take the nut off.
Old Apr 28, 2013 | 09:52 PM
martymcfly's Avatar
martymcfly
Default here is the answer.
Use an impact socket though. If the wheel is junk, you can weld a regular nut to the top of locking lug nut. Then take it off with a socket.
Old Apr 28, 2013 | 10:25 PM
don hall's Avatar
don hall
Is there a tool rental shop in the area? Save some $ renting instead of buying a removal tool from Sears, etc.
Using a smaller size socket (metric ?) as posted above, and hammered on usually performs well
Old Apr 28, 2013 | 11:17 PM
mazdaverx7's Avatar
mazdaverx7
PLRX has the right idea. it will keep damage to a minimum and you can get one of those tools relatively cheap.
Old Apr 30, 2013 | 12:27 AM
yaknow's Avatar
yaknow
have had to do this on both my C4 and C5. Takes about 1 minute per locking nut to remove
Old Apr 30, 2013 | 06:22 AM
trm 84's Avatar
trm 84
If you get a good picture of the lock, you can contact McGard and they should be able to sell you a new key.
Old Apr 30, 2013 | 12:28 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
X2... I used to do that all the time when I worked at a place that required removing locking lugs w/o keys on a regular basis. 12 point socket, hammer that b!tch on, hit it with an impact gun. Comes right off.
To Locking wheel nut
