jackstand placement
Old Apr 28, 2013 | 10:50 PM
tntwolt's Avatar
tntwolt
Default jackstand placement
have not really looked under my car, just where should i place jackstands? i`m using 4, it`s bad enough finding a placing for the floorjack.
Old Apr 28, 2013 | 11:03 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
I usually place mine under the shocks on all 4 corners, that way the suspension isn't just hanging.
Old Apr 28, 2013 | 11:06 PM
Aaron Keating's Avatar
Aaron Keating
I usually do mine under the shocks as well. More than strong enough to hold the car and not hurt anything.
Old Apr 29, 2013 | 02:22 AM
Cliff Harris's Avatar
Cliff Harris
I jack at the jack points and put the jack stands under the frame as close as possible to the jack.
Old Apr 29, 2013 | 12:00 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
Old Apr 29, 2013 | 07:53 PM
marks146's Avatar
marks146
Me too. God knows I've had mine up on stands a few times over the winter.
Old Apr 29, 2013 | 11:44 PM
383vett's Avatar
383vett
I just stated this in a similar post. Jack the car under the mirror. This will lift the whole side of the car. Place jackstands at the jacking points. Repeat on the other side.
Old Apr 30, 2013 | 12:08 AM
desertmike1's Avatar
desertmike1
where?
Old Apr 30, 2013 | 10:15 AM
383vett's Avatar
383vett
Originally Posted by desertmike1
where?
On the frame rail, not the mirror.
Old Apr 30, 2013 | 04:54 PM
ejscarfo's Avatar
ejscarfo
Never tried that....have to check that one out.
Old Apr 30, 2013 | 10:30 PM
tntwolt's Avatar
tntwolt
ahh! broke mirror off. just kidding, gave up on ramps for oil changes, i just slide them across garage floor and still can`t get under to drain an change oil filter.
Old May 1, 2013 | 12:14 AM
383vett's Avatar
383vett
You can do it, we're rooting for you.
Old May 1, 2013 | 07:51 AM
TA's Avatar
TA
Buy a set of the cheapest rubber floor mats you can find. I think the set I bought cost a wopping 7$ from Walmart. Put the floor mats under the ramps and, voila, they ramps will no longer slide.
To jackstand placement
