dash lights 882 or 882x
Old May 1, 2013 | 07:34 AM
redvetttes's Avatar
redvetttes
Default dash lights 882 or 882x
Read all about them,
some say you can't get the metal cover on the 882bulb what should
I buy ?
Old May 2, 2013 | 02:52 AM
Cliff Harris's Avatar
Cliff Harris
The definitive source of information on bulbs is Don's Bulbs. WAY more information than you could possibly use. According to his web site the only difference is the 882X is frosted:
http://www.donsbulbs.com/cgi-bin/r/b.pl/882.html
http://www.donsbulbs.com/cgi-bin/r/b.pl/882%7cx.html
One note about the 882: that number includes the socket. You can buy the bulbs without the socket as 891. Might save a bit if you don't need a new socket.
[EDIT] I recently found out (via Don's Bulbs) that the 891 bulb is rated about twice the power of the 882 bulb. That means that it will get even hotter than the 882, which is already roasting the sockets and PC board. [/EDIT]
Last edited by Cliff Harris; Jul 19, 2013 at 02:55 AM. Reason: Added note on 891 bulb.
Old May 2, 2013 | 06:46 AM
redvetttes's Avatar
redvetttes
change them the fast way,winshild washer hose works as a great bulb holder
Old May 3, 2013 | 01:45 AM
Cliff Harris
I use a telephone switchboard bayonet based bulb puller/inserter tool. Those things have gone way up in price as the switchboards have disappeared and everything went electronic. In a much earlier age I worked for a company that made telephone equipment. Jonard S-339:
This looks like a cool tool that will do the job:
http://www.millamusement.com/MillBulbTool.html
Old May 3, 2013 | 12:29 PM
mako41's Avatar
mako41
Wow at $36.00 per bulb I hope you use that site for information only.
To the OP you do not want to use the high heat 882 halogen instrument cluster bulbs for replacements. Later year C4's used lower heat producing Xenon bulbs (My '89 came with Stanley 7073 Xenon bulbs) that weren't prone to melting board sockets and burning boards.
Try these; more light, less heat, same wedge type base;
http://www.pegasuslighting.com/xenon...bs-5w-12v.html
If your looking to replace the Atari cluster backlighting read this thread;
http://forums.corvetteforum.com/c4-g...ent-guide.html
Old Jul 18, 2013 | 10:55 PM
Cliff Harris
Roger that. I don't know if he actually sells any bulbs at those prices. Maybe to folks who don't know how to do a Google search...
Anyhow, I looked at various bulb options and used Don's Bulbs to compare specs on the various bulbs:
Code:
882      891      7073     194
12.8V    12.8V    12.8V    14V
0.352A   0.625A   0.38A    0.27A
4.5W     8W       4.86W    3.78W
T2-1/4   T3-1/4   T3-1/4   T3-1/4
882 & 891 are bi-pin base. 7073 & 194 are wedge base. They obviously require different sockets, but otherwise are interchangeable.
So we see that the 891 is NOT just an 882 without the base, as someone suggested. It actually is TWICE the power, so it's going to get even hotter than the 882s. 882X is frosted, otherwise the same as a 882. [ EDiT ] It has come to my attention that the 882X bulbs do not come with the socket. They should be a little cheaper. [ /EDIT ]
The 7073 bulbs are NOT lower power than the 882s. In fact, they're a little hotter. Maybe the larger size helps dissipate the heat?
I put the 194s in there also, since some people have suggested them as a replacement for the 7073. They're rated at 14V, so will be dimmer at 12.8V, might be OK.
I don't know what bulb number the "Home Depot" bulbs are, so there's no way to compare them to the others.
Last edited by Cliff Harris; Dec 22, 2014 at 12:02 AM. Reason: Added note on 882X bulbs.
Old Jul 25, 2013 | 07:31 PM
mako41's Avatar
mako41
Code:
882      891      7073     194
4.5W     8W       4.86W    3.78W
The OEM Stanley 7073's are not halogens they are xenon gas bulbs that run much cooler than the previous 882 halogens.
To dash lights 882 or 882x
