problems w voltage
'84 corvette crossfire (78,4xx mi.)
a/c smog delete
k&n filter /hypertech chip
true duel and muffler deletes
Grounding:
Refer to the FSM and in particular you'll want to pay attention to the ground lugs to which several of the electronics, including the dash circuitry in particular, depend on a good connection.
Connections:
There is a rather large buss connector on the back of the cluster board. I have seen these connections become severely corroded or "frosted", due to reaction with the atmosphere. (I would replace them or use a contact cleaner to restore them as much as possible before applying a spray coat of connector protectant on the contacts. (Dry contacts...It's just a matter of time!)
Voltage Regulator:
The voltage regulator is located within the alternator. By measuring the voltage WITH A DIGITAL VOLT METER CONNECTED ACROSS THE BATTERY TERMINALS while revving the engine, should not affect the voltage more ±2-3 tenths ( will normally be 14.7 if under-hood temp is "cold", or about 13.8 if under-hood is hot after an extended run.
Now, the voltage regulator also depends on the field current which is provided by a number of connections, making its way back to the battery voltage when the power is ON. There should be a steady battery voltage at that connector. If it fluctuated or becomes intermittent, then the alternator output will also fluctuate.
Time to go troubleshooting!
P.
http://www.batee.com/corvette/dcrg/repair/
