High beam indicator light doesn't work
Old May 16, 2013 | 12:24 PM
salior13's Avatar
salior13
Cruising
Default High beam indicator light doesn't work
I have just purchased 1985 Corvette. When I did the test drive my high beam indicator dash light was working. The first time out at night it didn't. Are there any common things I should be looking for? Is there easy access to the bulb?. At this time I don't have an owners manual.
Hoping there is some out there who can help.
Gord
Old May 16, 2013 | 11:38 PM
Cliff Harris's Avatar
Cliff Harris
You need to remove the instrument panel bezel to get to the bulb. The headlight **** has a clip that needs to be released to get it off the shaft. There is a notch in the bottom of the **** for that. The bezel wraps around and there is one screw at the very front that is sorta hidden (and hard to get to). I use a stubby Philips for that one.
The high beam and turn signal bulbs are #74.
Old May 18, 2013 | 11:23 AM
salior13's Avatar
salior13
Cruising
Default Thanks, Cliff
Thanks for the info Cliff. I'm away from home now but I'll will be checking it out as soon as possible.
Gord
To High beam indicator light doesn't work
