Is this normal?
Old May 31, 2013 | 08:32 AM
Stig.Vette's Avatar
Stig.Vette
Default Is this normal?
Ok, how about this - (now, I'm new to corvettes and this car specifically, so be gentle)
When I drive with the headlights on and then park, I can turn the ignition off and pull out the key while the engine still runs. The engine will stay running until I turn the headlights off - then it shuts down. Now, while the key is out of the ignition but the motor and lights are still on, I can open the doors and the engine stays running. I haven't tried shifting out of park yet, so I don't know if that's possible.
Do all C4s/'Vettes do this? Is this a remnant of a remote start system? Bad wiring, etc.?
I haven't had this car long and don't know many details of it's past, but I've never owned a car that did THIS!
Old May 31, 2013 | 08:54 AM
gerardvg's Avatar
gerardvg
No that is not normal at all, sounds like a ground wire issue or something. Hopefully someone on this forum has come across something similar to help you fix it.
Old May 31, 2013 | 09:01 AM
Muffin's Avatar
Muffin
Not normal and sounds dangerous.
Old May 31, 2013 | 09:15 AM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
Old May 31, 2013 | 09:20 AM
WGlen C4's Avatar
WGlen C4
That is messed up! Although taking the keys out of a running GM product while in the on position is normal for a worn out lockset. My Tahoe, Chevelle, and Sierra all did this.
Old May 31, 2013 | 10:16 AM
Stig.Vette's Avatar
Stig.Vette
Wow! Thanks guys, glad I asked about it. It sounds like I should investigate this, pronto.
They key is tight when in the tumbler. It's only when the ignition is in the off position and the key is removed normally that I experience this.
Does anyone have any guess how the headlight circuit and engine cutoff/ignition circuit could get intermingled? I guess I need to get my hands on a wiring diagram and take a voltmeter to the system.
Old May 31, 2013 | 10:18 AM
ch@0s's Avatar
ch@0s
Sounds like an ignition problem.
Old May 31, 2013 | 10:25 AM
DaveP85C4's Avatar
DaveP85C4
Or take down the drivers side hush panel and look for any aftermarket wiring, modules, relays etc. Trace and remove any connections from aforementioned devices to stock wiring. Many Directed Electronics (Viper, Cobra, Python, many other brands) alarms and remote starts have additional modules added to them at installation for headlight on, auto window close, door lock interface, etc. Some of the damage done to electrical systems by installers can be breathtaking.
Pull down the hush panel and take a look. Good Luck.
Old May 31, 2013 | 10:29 AM
NotAnExpert's Avatar
NotAnExpert
St. Jude Donor '13
Yes thats perfectly normal. In fact cars today dont even have keys, just key fobs and ignition. C4's were ground breaking in this technology, first designing an ignition that could work with the key removed. I recommend trying while driving down the road.
Seriously thats not nirmal for any car. It needs attention. No telling what will happen if the issue goes unresolved and progresses into something even more dangerous.
Old May 31, 2013 | 11:08 AM
roydettmer's Avatar
roydettmer
sounds like someone has tied the coil ignition wire to the headlite load lead somewhere probably under the hood.
Old May 31, 2013 | 01:06 PM
Stig.Vette's Avatar
Stig.Vette
That sounds like a very educated guess. I'll start there.
hahaha! You never know what kind of barrier-shattering attempts GM engineers might make on these cars!
I'm not sure about trying this while I'm going down the road... but, I did try the "shift out of park" experiment when I got back from lunch: no dice. Everything is locked up tight (steering, trans, brakes, etc. behave as if the engine were off).
Old May 31, 2013 | 01:09 PM
Stig.Vette's Avatar
Stig.Vette
Oh, I also began looking for an '89 FSM with Elec Diag Supplement in the Parts Wanted section of the forum. Those are a bit pricy online right now; $110 (used) and up.
Old May 31, 2013 | 02:44 PM
ch@0s's Avatar
ch@0s
When I say ignition I'm not talking about the lock cylinder. I'm talking about the actual electrical switch that controls whether the car is on, off, or in ACC mode. When there is trouble with the switch pretty funny things can happen. This switch is responsible for directing power etc.
Old May 31, 2013 | 07:06 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Dang thing is possessed. Either that or your ex gf and or wifey are trying to do you in.
Old May 31, 2013 | 07:11 PM
bangbgC6's Avatar
bangbgC6
I found my Red Cover for my '89 at our local Corvette/VW swap meet @ Pomona Fairgrounds and paid $80.00 for one in great shape. That same company sells auto service manuals and books online. $110 doesn't sound too bad, it has a sh!tload of valuable info that in my mind is priceless.
St. Louis is a big city, maybe you guys have a local swap meet where these vendors go.
Old Jun 1, 2013 | 06:09 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default headlights
Sounds like the remote start is messed up.
There has to be a module that lets the engine starrt with no key. the module has to have a lights on function for newer cars with daylight driving lights.
Since we don't have this, the module might keep the ignition running thinking it is the light wire if it is hooked up wrong.
That's probably the wrong application for the remote start kit.
Old Jun 3, 2013 | 01:09 PM
Stig.Vette's Avatar
Stig.Vette
Thanks for the tip about corvette swap meets, I wouldn't've thought of that. A vendor responded to my post in the parts forum - $85 shipped for a slightly used one (looks in great shape). That one doesn't come with the electrical diagnosis supplement though. Not sure what I'll do...
This weekend was too busy anyway with family in town. I won't have a chance to look at the car until next weekend at the earliest. I'll update when I know more.
To Is this normal?
Old Jun 3, 2013 | 08:55 PM
Speedjester's Avatar
Speedjester
I don't know how it's done... But some of the cruisers in our fleet ... Have something installed... That as long as the headlights are on the car will remain running... ( lets you keep everything on without having to watch the vehicle) ..You can't drive or rev it unless you put the key in...
Old Jun 4, 2013 | 01:50 PM
bangbgC6's Avatar
bangbgC6
I think the supplement was $30.00 @ that same vendor. You will be able to find one.
Old Jun 4, 2013 | 03:23 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
A lot of people mistake the ignition for the key cylinder.
