Help!!! Battery Keeps Dying!!!
ok so, i worked on the car's interior for about 4 hours with the light dimmer turned all the way up to illuminate the interior and i checked the turn signals/fog lights for about a minute and flipped the headlights open 4-5 times with the car off but that shouldn't run out a new battery should it? Here are some of my concerns:
1) If i turn the key to ignition, the radio display comes on but wont shut off until i open the passenger door, not the drivers door.
2) If i turn the key to ignition, the green a/c light starts blinking even when i hit OFF, is that normal?
3)When i tried turning the car on yesterday, the instrument cluster would light up and the digital display indicated 11.1 volts. Today nothing except check engine light on the DIC display lit up and the a/c started blowing!?!?!
4) I went to disconnect the negative battery cable and as soon as it disconnected, the headlight motor started spinning (did not open the headlight, just started pumping).
5) the radio antenna will not extend and i have read this is somehow related to draining the battery?
I'm taking the car to my mechanic this wednesday after I go get a new battery. but until then what should i try? Will a battery draw test work with a dying battery?
1) I am not too sure if this is a door switch issue, but I have seen the same thing happen on my car.
2) When the battery power is pulled in my car, it resets the hvac system and the next time power is applied to the car it comes on like you stated, so I assume it is normal.
3) The A/C light blinking usually means there is an issue with the system (maybe low freon) there is a way to pull error codes directly on the hvac system, it may be in one of the sticky tech links.
4) The sound you are hearing from the headlight is because your bushings are worn out. The motor runs for a set period of time before it shuts off if the bushing are worn. It is a relatively painless hour per headlight to fix. I followed a youtube video on how to do it. This is also probably the root cause of your battery dying. Since the headlight motor doesn't turn off and can keep running. My thread when I did the repair:http://forums.corvetteforum.com/c4-g...ht-motors.html
5) I can't help with this one, someone else will most likely be able to jump in.
I kept my car on a battery tender until I got the headlights fixed to prevent the battery from being drawn down. Good luck with the car, hopefully this was a little helpful.
https://www.corvetteforum.com/techti...=193&TopicID=2
I would disconnect the battery and put a volt meter between the battery and the negative cable. Then have someone start and pull fuses one at a time until you find which system is drawing the battery down.
They sell them at any auto parts store.
http://www.ecklerscorvette.com/batte...side-post.html
Since you can only access the main fuse panel with passenger door open, before pulling fuses to find the problem area you will need to hold the door open sw closed long enough for all the interior lights to go Off.
Here is a You-Tube vid (
It seems to me that a bunch of electrical devices all starting to display odd behavior at the same time, probably means that your battery has gone from new to dead both times. If any micro-processor is receiving low voltage, it can/will do some crazy stuff! My guess, based on info so far, is a bad alternator. Best of luck! John
Mahdi, I just re-read your first post, when you're getting the new battery, ask them to check your alternator. They typically do this for free.
In the past couple of days I turned the headlights on and back off an only one headlight closed. The Rightside Headlight I know needs a new gear/bushings and the left side old motor gets stuck in the up position...The Left side headlight motor has been stuck in the up position for the last 3 days! When I touched the negative side cable to the battery this morning I heard a "click" sound from the leftside and then the right side motor started spinning. I disconnected it and kept trying it until I noticed that everytime I connect the negative cable to the battery, the Headlights try to move! Is that normal when connecting the battery to the car or could this be whats draining my battery?!?!? One way or another I'm taking the car to my mechanic tomorrow!Would anyone possibly be willing to try this on their car??? Disconnecting the battery and reconnecting it to see if the headlights do anything?? Thanks!
Besides a few solenoid clicks... just sits there quiet and silent.
