V08 question
One thing I HAVE noticed, though, is that the car runs hotter (about 10 degrees higher while driving) with the AC on. My 95 runs cooler while driving with the AC on, so just the opposite.
Re the a/c - it should run cooler with the a/c on (idle and low speed - freeway should be around the thermostat regardless of whether it's on or off). What's going on in the Condenser has to be well below the thermostat or the pressure can reach a point where it blows a hole in the hood (thankfully, there's a high limit to shut it off - 400 psi). Anyway, the fan is on sooner and stays on longer than if the a/c were off, the resulting benefit being the lower Coolant Temps (and if you're interested, a/c operation is exempt from Federal emissions which is why the tech turns it off when it's tested). You could have an a/c shop hook up some gages to see what's going on, but first I'd check to make sure everything is clean and free of bugs, debris between the Condenser and Radiator, and that the Spoiler hasn't taken too many hits from parking lot stops or speed bumps. The fan, for a/c operation (R12 gas) should click on at close to 230 psi which is a saturation temp of 145 degrees and then run until 190 psi or 134 degrees. With subcooling, the liquid is easily 10 degrees cooler and touching a digital thermometer to the high line as it exits the Condenser will tell you what the temp is. Then, if you know what the High Side Pressure is, you can get the subcooling from a Pressure/Temp Chart. No or very low subcooling generally indicates a bad compressor, but auto a/c guys rarely if ever consider this measurement and simply rely on what their gages show.
