grounds
Old Jun 13, 2013 | 10:23 AM
cinor's Avatar
cinor
Default grounds
R there any main grounds direct to the frame and if so where are they located had new stereo installed and having some trouble with dash readings but I think it is more than likely in the grounding
Old Jun 13, 2013 | 01:10 PM
ch@0s's Avatar
ch@0s
If I were you I would take it back to whoever installed it and have them fix it. What exactly is the problem?
Old Jun 13, 2013 | 10:56 PM
csthews's Avatar
csthews
I know of two inside a 95 coupe. If you pull the floor carpet back along the left and right walls and just below the dash, you will find grounds.
Old Jun 14, 2013 | 02:39 AM
Cliff Harris's Avatar
Cliff Harris
I don't know about later years, but on my '86 the battery is connected directly from the negative terminal to the frame. The negative battery cable bolts to the side of the engine block and there is also a braided ground strap from the block to the frame. Kind of redundant.
Old Jun 14, 2013 | 05:12 AM
ricasso's Avatar
ricasso
When I fitted my new system I just spliced into the existing loom that supplied the original Bose unit, it was interesting to see how few wires were needed for the new head unit, didnt have to find a separate ground.
For the new Amp (in the back) I had to run a power cable to it direct from the Battery, so the easiest thing to do was run TWO cables, the other being for the ground, straight back to the battery, cant go wrong then!
To grounds
