Ok iam wondering which is best to use. 50/50 anti-freeze or water and Wetter Water Additive..
You can use the wetter water with anit-freeze but does not lower the temp as much.
Anti-freeze also contains chemicals to help the cooling system from developing deposits like rust and scale. They provide protection for the system in a wide range of air temperatures.
Use a good grade of anti-freeze mixed with distilled water in a 50-50 ratio. That mix provides freezing protection to -37 degrees and also helps in hot climates.
