Led tailight hyperflash fix
Old Jun 26, 2013 | 04:08 PM
DRidgeway's Avatar
DRidgeway
Default Led tailight hyperflash fix
Good afternoon,
I purchased a pair of LED tailights from Corvettemods but through a mix up didnt get the "Anti-Hyperflash Resistors" sent.
As a result, I was told the turn signals dont work.
I have my car at a mechanic 1600 miles away trying to get some small things done before I'm reunited with her next week.
I'm kind of flying in the dark since Imso far away...but what exactlydo I need?
The website describes them as Add Anti-Hyperflash Resistors
Is the the same thing as an electronic turn signal flasher?
If so, I assume they can be had at any O'reiley's., Autozone etc?
Correct>
I never realized moving a car across country could be such a hassle when even little things come up that you cant physically put your hands on.
Any info, pointers or specific models greatly appriciated
Wade
Old Jun 26, 2013 | 05:35 PM
Goldcylon's Avatar
Goldcylon
Install an electronic flasher. You dont need resistors. Ive been running LED everything for more than 6 years now.
Old Jun 26, 2013 | 05:50 PM
DRidgeway's Avatar
DRidgeway
THANKS Gold Cylon ..I'll pass it along...and post pics afterwards.
Old Jun 26, 2013 | 06:47 PM
Goldcylon's Avatar
Goldcylon
Old Jun 27, 2013 | 07:52 AM
Boxcar's Avatar
Boxcar
Life Starts at 120 mph
NCM Lifetime Member
[QUOTE=DRidgeway;1584255316]
Wade, here is what I know, and Cylon is correct depending on...
My research into this; your factory lights draw a different voltage, wattage then having low volt LED. There by causing the flasher to think a bulb is burned out and giving you the “hyperflash”. Adding a “anti’hyperflash” device, which is regulated differently, with the correct voltage, wattage stops all that. It’s that simple. The one you buy from parts store will not fix this problem, because they are regulated to factory specs.
As for the rest of the car, LEDs is fine, should and will work fine. Just thought you should know.
Boxcar
Old Jun 27, 2013 | 09:26 AM
Goldcylon's Avatar
Goldcylon
[QUOTE=Boxcar;1584260398]
Boxcar
Goldcylon is right because hes been there and done that. The electronic flasher will solve the problem. Just thought you should know
Old Jun 27, 2013 | 10:51 AM
mrmtrtrnd's Avatar
mrmtrtrnd
This has been used by numerous members including myself. I've had LED taillights for three years with nothing else installed but the taillights and flasher.
Old Jun 27, 2013 | 11:32 AM
DRidgeway's Avatar
DRidgeway
Thanks guys,
I Googled an EL-12 flasher and found one at Advanced auto parts.
Apparently, the "mechanic" had/has no idea what a electronic flasher was or what I was talking about.
It will be good to have the car in my hands once again, to figure these things out myself and with the furum's help!
Old Jun 27, 2013 | 11:38 AM
Goldcylon's Avatar
Goldcylon
Thanks guys,
Older car with new technology doesnt happen all the time. Thats why its best to ask here. Somebody has seen a problem or done something before. Whats important is you share so the forum benefits. Cant wait for pics. As I always say there is no good reason while the C4 body style I choose to own cant be up to 21st century standards.
In the mean while here are mine that have been running strong for 6 years. Also the back up lights are LEDs
LED CMHSL Yes those are metal louvers as well
Old Jun 27, 2013 | 09:36 PM
Chuck Tribolet's Avatar
Chuck Tribolet
Voltage is the same in both cases.
The factory flasher is driven by the current drawn by the lights. The
LEDs pull lots less current so the factory flasher will not work
correctly.
The electronic flasher has an internal timer circuit that is independent
of the current. It doesn't much care what the load (and therefore
current) is, within reason.
Chuck
Old Jun 27, 2013 | 09:53 PM
mrmtrtrnd's Avatar
mrmtrtrnd
[/QUOTE]
Is your center stoplight a red lens with LED? I've been looking for one for my vette for a couple of years and the only thing I've seen is clear, smoked or black. I don't have the high mounted light so I don't know if that makes a difference.
Old Jun 27, 2013 | 10:10 PM
Goldcylon's Avatar
Goldcylon
Yes the lens is oem the interior was converted to LEDs
Old Jun 27, 2013 | 11:21 PM
mrmtrtrnd's Avatar
mrmtrtrnd
Ok I better get after it and do the same. I don't know why they don't make a plug and play for the third taillight.
Old Jun 28, 2013 | 09:25 AM
Goldcylon's Avatar
Goldcylon
They dont that looks like this with the CMHSL. This was a custom build by a forum member. They do have LED replacement bulbs out there but then you get only 4 lights within the lens and it does not diffuse right.
Ebay sells the LED Strip kind that fit in the rear fiasca that im aware of. However, nobody is doing the CMHSLs
Old Jun 28, 2013 | 01:05 PM
DRidgeway's Avatar
DRidgeway
I'll have more sent when it's dark.
HID's
Old Jun 29, 2013 | 01:43 AM
DRidgeway's Avatar
DRidgeway
Old Jul 1, 2013 | 08:37 AM
Goldcylon's Avatar
Goldcylon
Looks like the flashers working
Awesome pic go Cards
To Led tailight hyperflash fix
