Idle Control Motor
Old Jul 5, 2013 | 09:22 PM
hafferf's Avatar
hafferf
Default Idle Control Motor
Howdy Folks!!...
I'm a newbie to this site, but I've had several C-4's This one is a 1988 35th Ann. Coupe. My problem is that she idles rough, and you have to press on the accelerator while cranking to get her to start. That rings the old "Idle Control Motor" bell, but I can't find a schematic that show where it is, or more importantly, a stock number so I can order one. Does Vette have something different that does this chore? Any help appreciated.
Drive On!!...
Fast Freddie
Old Jul 5, 2013 | 10:58 PM
John A. Marker's Avatar
John A. Marker
It should be located on the passenger's side of the throttle body...under the body. Should be a four wire weather pac plugged into it.
Old Jul 6, 2013 | 12:01 PM
hafferf's Avatar
hafferf
Thank you Sir!!... I had another fellow tell me that it could be a vacuum leak... so I've got my work cut-out for me...
Thanks Again
Fast Freddie
Old Jul 6, 2013 | 12:10 PM
bob guzzy's Avatar
bob guzzy
It could also be the TPS sensor is out of range what you need to do is get a volt meter and check the tps.
The blue(middle wire on my 90) wire is the power, you can ground it anywhere you can get a ground, turn the key to the on(not running) position, look and see what the reading is, I have mine set between 0.50 and 0.58V.
Mine starts OK I'm fighting with a wandering idle at the moment
Old Jul 8, 2013 | 02:51 AM
Cliff Harris's Avatar
Cliff Harris
Sounds like you need to do a minimum idle adjustment:
http://home.earthlink.net/~cliff_har...djustment.html
To Idle Control Motor
