distributor cap am I the only one who hates it?
Old 07-13-2013, 01:21 PM
rgouette
rgouette's Avatar
Default distributor cap am I the only one who hates it?
As I started messing with my project, I quickly found the cap to be really tough to pop onto the base, due to the location at the extreme rear of the engine.
I found I cannot lock the rear hold-down because it's basically underneath the body..
I ended up bending the rotor metal contact in trying to position the cap ...was frustrating
Just curious if folks have as hard a time as I do with the dist cap.
Rich
Old 07-13-2013, 01:53 PM
84wuzmy1st
84wuzmy1st's Avatar
What year? In my 85 my cap bolts on, but yeah the 2 back bolts are a pain. I found the best way to get at them was a socket screwdriver and an extension.
Old 07-13-2013, 05:53 PM
Sleazy Rider
Sleazy Rider's Avatar
Just get the cap in place then pull back on the hood seal and use swivel socket to tighten down the screws.
Old 07-13-2013, 06:46 PM
rgouette
rgouette's Avatar
swivel socket...hmm
my original, and replacement are the push down spring-loaded thingies & I use a straight slot to push down.
when the cap is installed, I don't see how I can even get to the rear latch: but maybe I'm just not patient enough
Old 07-14-2013, 08:57 AM
JackDidley
JackDidley's Avatar
I dont think you have the original dist. Every C4 ive looked at had 4 screws holding the cap. 1/4" drive with a long extension makes it do able.
Old 07-14-2013, 09:11 AM
vl5150
vl5150's Avatar
My 1990 OEM cap went right on like stated above with a socket extension and a rearward press on the weatherstripping to line it all up.
Old 07-14-2013, 08:08 PM
vetteoz
vetteoz's Avatar
Except '84 apparently
http://forums.corvetteforum.com/c4-t...butor-cap.html
Old 07-14-2013, 08:22 PM
Muffin
Support Corvetteforum!
Muffin's Avatar
This works for me.
Old 07-14-2013, 08:28 PM
rgouette
rgouette's Avatar
Okay so the verdict is the 84 C4 has a spring-loaded?
I think I'll look in my manual and see what it shows the right says haven't even looked yet
Old 07-14-2013, 09:11 PM
vetteoz
vetteoz's Avatar
Could always mark the dist and intake manifold , loosen the retainer bolt slightly so you can rotate the dist to access the cap lock down clips,
then reposition and tighten down the dist when you are finished ?
Old 07-15-2013, 06:48 AM
rgouette
rgouette's Avatar
well fellas, here ya go: right from the horses patootie:
To distributor cap am I the only one who hates it?
Quick Reply: distributor cap am I the only one who hates it?
