SYS error flashing on display
Old Jul 29, 2013 | 11:00 AM
Nolanjj24's Avatar
Nolanjj24
Default SYS error flashing on display
Hi everyone,
Need some more ideas of what could be causing that error to flash. Read on here it maybe the ground wire from the battery so I went ahead and took the battery out and cleaned the wire, nut, screw, and contact point and then put the battery back and to my dismay saw that stupid SYS flash every 15 seconds. I am not seeing any loss in power with the motor so it hasnt been a big deal but now I have that CHANGE OIL light on so it's more of an eye sore than just not being able to reset a trip meter or fuel ... Any thoughts are greatly appreciated.
Take care and keep it AMERICAN,
Nolan
Old Jul 29, 2013 | 11:20 AM
SoAlVette's Avatar
SoAlVette
Have you installed a new stereo system recently?
Old Jul 29, 2013 | 11:29 AM
Nolanjj24's Avatar
Nolanjj24
Nope ... she is all original, the regular things have been changed over the years but electrically speaking no mods of any sort.
Old Jul 29, 2013 | 11:34 AM
Goldcylon's Avatar
Goldcylon
You have an internal short in your battery. Replace it and the "SYS" should go away
Old Jul 29, 2013 | 11:56 AM
96 Vette CE's Avatar
96 Vette CE
Banned Loser
From: They say you learn from your mistakes, I must be a genius
2017 Corvette of the Year
2016 C4 of Year Finalist
Creator of the "Original" whining and crying thread
St. Jude Donor '14-'15-'16-'17
Weak battery is usually the cause.
Old Jul 29, 2013 | 12:08 PM
Nolanjj24's Avatar
Nolanjj24
Awesome thank you guys. I will try that and follow up. No better place, hands down, than here to get the help needed to make these beautiful rides function as they should. Thanks again.
Old Jul 29, 2013 | 01:06 PM
davewhtt's Avatar
davewhtt
Not always battery,trust me if you have a drain somewhere it will SYS. I have new battery alternator chrging real good. If car sits for more than 48hrs ill get the SYS but only for 15 mins. It will happen if you start car and it shows a low charge on battery. Its plenty to start car but a little under a full charge.
Old Jul 29, 2013 | 03:54 PM
Streamline's Avatar
Streamline
I had installed a new rebuilt REMYstarter on mine, SYS came on.... had the starter tested and that was pulling too much amperage. Reinstalled the old one, no problem, SYS went away.
To SYS error flashing on display
