ASR Question
Old Aug 3, 2013 | 04:31 PM
HGUNHNTR's Avatar
HGUNHNTR
Default ASR Question
Hey folks. Quick and easy question for y'all. Is it normal for the brake to momentarily engage under hard acceleration even with the ASR switched off?
Thanks for your time.
Old Aug 3, 2013 | 04:39 PM
Mo_Bandy's Avatar
Mo_Bandy
I would say no not to my knowledge, my experience has been with ASR off nothing should activate.
Mo
Old Aug 3, 2013 | 05:05 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
No.
Old Aug 3, 2013 | 05:26 PM
HGUNHNTR's Avatar
HGUNHNTR
hmm, the light on the dash says it is deactivated, but the brake light does occasionally come on during heavy acceleration. Am I correct in assuming that the only thing I need to do to disengage the ASR is to just press the button?
Any ideas on troubleshooting this?
Thanks again gang.
Old Aug 3, 2013 | 06:10 PM
zr1fred's Avatar
zr1fred
The brake light doesn't mean your brakes are activating, it means your car thinks it is out of brake fluid. Check the wire that goes on the master cylinder. Depending upon the year and which light, it could also be a problem with the Ebrake switch or wiring. To disengage the ASR, just push the button
Old Aug 4, 2013 | 01:14 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
That, or it's simply low on brake fluid and what is in there is sloshing to the rear of the reservoir during hard acceleration.
Old Aug 4, 2013 | 10:09 AM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Yep
Old Aug 5, 2013 | 06:52 PM
HGUNHNTR's Avatar
HGUNHNTR
That was it! zr1Fred +1 This site is awesome!
$48 later and it's fixed.
To ASR Question
