There are many arguments on tstat temps. GM put the 195 in for a reason. That being said I have a 180* stat in mine, just changed it out from a 160*. Your car will run at what ever temp it normally runs at no matter what you decide to put in.
The statement above is what alot of people fail to realize.. Having a lower temp thermostat only means it will open sooner, the car will run at the temperture that it always has.. To make the car run cooler something in the system has to be changed , "only then" will it run below the temperture the factory has set it up to run...WW
180 is ideal in these cars. It gives the best of both worlds. Your heat will still work good in the winter this way,but your engine will run a lot cooler. Your fans can be programmed to come on much earlier if you get a custom chip made. Your engine will never go over 200 degrees.
Cars generally sit at the thermostat temp + 5 deg. or hotter on demand. Just lowering the stat temp isn't as effective as doing it with a chip to take advantage of it with more spark advance. A Hypertec II chip will do this and specifically wants a 160 stat. Did great on my 89. It will on an 87 too. Add an adjustable fuel pressure regulator and you have a nice setup. An extra pound or two on the fuel pressure helps.
maybe someone wants to explain why they want to change the temp that the engineers designed for the car to run at
GM uses the hotter temps for a more efficient and complete burn. Stock runs anywhere from 195 to 226 before the primary fan comes on. While this is great to get the best mileage it does come at a cost. Colder air is more dense, and a denser intake air will create more power. Also, hotter temps create greater pressure in the coolant system. With the C4 cars now approaching 20 years or older some feel the colder air charge, and reduced pressure is worth it.
I run a 180 T stat, and have programmed my fans to come on at 200, and off 190. My ecm shuts them off at 35 mph.
I've been around this forum for a while now, not new to the breed - but really would love to know how to reprogram my fans. I've tried everything and still run consistent temps in the 215 - 220 range. I agree it's an older car and it simply worries me to run that high. To the point I'm reluctant to drive the car on days when I'd love to!
I have no interest in making the EPA happy, heat destroys everything under the hood, it stresses the head gaskets and hoses. I can still get 30 mpg on the highway if I'm careful but WHY? This is a fun car, not a daily driver.
Im sorry totaly disagree the car should run at hightway speeds close to what the thermost set point is. That is the whole puropse of a thermost to maintain temp. Now with no consent air moving aacross the rad there is no waay to cool down the cooleant and temps rise this is where where the fans take place. they will cool the colleant enough to keep the car from over heating untll you are moving and full air flow is across the Rad
Perhaps the most common example of purely mechanical thermostat technology in use today is the internal combustion engine cooling system thermostat, used to maintain the engine near its optimum operating temperature by regulating the flow of coolant to an air-cooled radiator. This type of thermostat operates using a sealed chamber containing a wax pellet that melts and expands at a set temperature. The expansion of the chamber operates a rod which opens a valve when the operating temperature is exceeded. The operating temperature is determined by the composition of the wax. Once the operating temperature is reached, the thermostat progressively increases or decreases its opening in response to temperature changes, dynamically balancing the coolant recirculation flow and coolant flow to the radiator to maintain the engine temperature in the optimum range.
Reason: delete some info
GM ran the cars hot to reduce emissions and try to sequeeze all the fuel economy out of them possible - doing the best they could to appease the EPA, plain and simple.
Keep in mind what the function of a t-stat is in the cooling system. The job of the t-stat is to regulate the flow of water from the engine to the radiator and back again. When the engine is dead cold, the stat is closed and water stays in the engine till the stat opens. When that happens, the hot water flows into the radiator and the cool water from the radiator flows into the engine. That cool water closes the stat and is then heated by the engine while the hot water in the radiator cools. They cycle then repeats.
Many people don't understand that if a car is running too hot "overheating" (due to a clogged radiator or some other mechanical problem) that putting in a lower temp stat makes the problem worse because the water then has less time to shed heat in the radiator.
If you want to run a lower temp stat there's nothing wrong with that as long as you also make sure the computer knows to expect a lower operating temperature and that the fans come on and turn off at matching (reduced) temps.
As stated before, the hotter the engine, the more all the plastic connectors etc., are "cooked" by engine heat.
Good information on how a stat works some people think once it is open its job is over. the stat flucates to maintain its setting as close as possible
He is absolutely correct on this. A 180 Thermo is perfect on these cars along with a custom chip to correct the fan temps.
