i left the mid level lights on all night in my 1993 vette, wasnt paying attention i guess,
when i went out to check it was completely dead and there was no sound of the starter even trying to turn.
a few hours later some of the warning lights would come on and the PKE light would come on and make a noise as soon as the key came out so there is like almost no power left
i want to jump start it to get the car going again but wanted to know if there is anything special i need to do for a vette battery, i was just going to use my gf's car and do a normal jump and wanted to make sure that would cause any problems,
any tips on how to get the battery charged again would be helpful
Make sure your ignition is off before hooking up a charger or jumper cables. Doing so with the ignition on can cause problems with your CCM. The previous owner of my 90 vert could have used this advice. On the other hand, I wouldn't have this car now if he had.
alright good to know! thank you!
i believe i have a ecm..should be same thing though
so i should hook everything up and then put the key and the ignition and try to start up the engine?
i just really dont want to kill the electronics on the car doing this!
the ECM is under the hood and the CCM is in the dash behind your stereo. Yes, just make sure the ignition is not on, hook up your jumper cables and then try to start it. 99% of the time that is the way people do it without thinking about it. The guy that owned mine went out to start it and the battery was dead. He neglected to turn off the ignition, hooked up the battery charger, and the rest is history, it destroyed the CCM. Of course he didn't know that and started shotgunning parts at it, disassembled the dash clear to the firewall and before he knew it, he was way over his head.
If it were me i wouldn't jump it at all. I would do what Airforceone said in his post and buy a good battery tender to bring it back to life. You'll need it anyway.
Jump starting is very hard on the alternator. It may take longer to charge but you should use a battery charger instead and let the battery fully charge.
Yes.
Let's not be alarmists here, about alternators, etc. The alternator is perfectly able to deal w/the load placed on it by charging the battery. I've jumped my 'Vette many times (and hundreds of other cars/trucks) and never seen any negative consequences as a result. Pretty standard thing to do.
"Jump starting or using a battery charger can be dangerous if care isn’t taken when the cables are installed. Always connect the positive cable of the vehicle to be jumped at the battery. Then connect the ground cable of the vehicle to be jumped up to the alternator or any bracket that will give a good ground to the system. This prevents sparks at the battery from ruining your day even more! Whether you’re using a set of jumper cables or a battery charger, wait and let the dead battery charge up for 10-15 minutes before attempting to start the car. Completely dead batteries can take much more time before they will be charged enough to start the car, especially when using inexpensive jumper battery cables. You also run the risk of damaging computer components when the voltage spikes from jump starting, so wait for a while and let the battery charge before making the start attempt. The best battery maintenance tool on the market for your battery is the Battery Tender. The Battery Tender keeps the battery at optimum charge level without overheating the battery while monitoring ambient temperature. "
They OP left his lights on. Most of us have done it. Why does he need a battery tender?
Battery tenders are not meant to charge dead batteries
Sean, maybe if you wash your car you would be able to see that your lights are on.
ha kim you couldnt resist! next weekend i am actually going to wash it.
and ya i ended up using a battery tender charger and it seemed like it worked fine, started right up and the only thing was the lcd display showed a "sys" message for a while that kept coming on as i switched between readings.
my battery wasnt fully dead, the pke light a few others were dimly lit and it was making a clicking sound like the car alarm trying to go off.
lol that is where most people fail. these are cars there is really nothing special put into them then in other car. the cooling system has really not changed sense the start of liquid cooling. the engins can be found in everything from trucks to taxi cabs, brakes no difference and so on. Treat them just like any other car
totaly agree, Iv probley jumped more vehicles in one day then most have jumped in their lives never have I seen a neg effect of the alt charging system ect
not trying to start a braw here but why would he need a battery tender anyway? and tenders are generly not made to bring a dead battery up to charge they are designed to maitain the charge. to charge a batter you need a charger. To me there is no reason to have a tender on the car unless it sits for a month at a time. These things are not special I dont see or here of people puting a tender on any of the other cars they drive
