Broken PCM bracket fix
Old Aug 27, 2013 | 12:24 PM
Elrick's Avatar
Elrick
Default Broken PCM bracket fix
I have a 96 and the bracket/stud that holds it to the firewall has broken off. I cant see that there are any screws or bolts holding this plate on. Its right where the brake booster attaches so I would have to remove all that but I have not been able to locate this part. Has anyone had to deal with this? it's looking like my only option will be to fabricate something. hopefully a little better then the zip ties I have on there now. Thanks
Old Aug 27, 2013 | 01:34 PM
NitroNutt's Avatar
NitroNutt
I got mine from the parts area of this website. You have to take booster off firewall. I have the ZR1 booster and it has a different arc to it than single reservoir booster so I had to shim bottom with washers to match ZR1 booster plate/bracket.
Old Aug 27, 2013 | 02:23 PM
Elrick's Avatar
Elrick
so then it is like a plate with the stud on it that attaches to the fire wall. how does it attach, bolted or rivet. I just cant see the attachment point because the booster is in the way. if anyone knows of a source or has one please let me know. Thanks
Old Sep 4, 2013 | 04:09 PM
NitroNutt's Avatar
NitroNutt
The booster bolts are what hold the bracket.
To Broken PCM bracket fix
