Jack Stand Safety
Old Aug 29, 2013 | 12:56 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
Just use what you have....like this guy:
He's even using a wheel chock for safety.
Old Aug 29, 2013 | 01:03 PM
ercriss's Avatar
ercriss
Well I'm freaked out now. Shopping around for a mechanic to do the job for me now. After the cost of jack stands and backup blocks I'm only saving about 250 in labor. Not worth the hassle and risk at this point.
ercriss's Avatar
ercriss
I will however keep my eyes open for cheap 6x6 timbers for the future.
Old Aug 29, 2013 | 01:19 PM
Goldcylon's Avatar
Goldcylon
Originally Posted by Tom400CFI
Dramatic...but your friend failed at step 1 and step 2; good stands, getting the car on them properly. Cars shouldn't be falling off stands.
No Chit, im also telling a story that happened in 1979
Having a less-than-ideal BACK-UP is hardly a "death wish" however, and that was my point.
You have a point? Your argument is less than ideal is ideal which makes no sense what so ever. If its less than ideal it ='s Dangerous
The OP is obviously safety conscious, using two systems to support the car, and asking for opinions too.
Concrete blocks are never a good option or never should be a primary or secondary option which was MY point. I already said the OP was smart enough to ask for opinions.
"Death wish"? No.
Anybody who uses blocks as a part of any "Safety" system or second stage of supporting a car is unsafe and has a "Death wish" in my opinion. You dont agree, fine, IDK what you think, believe, feel or have to say. Supporting the use of concrete blocks is a hollow argument.
Old Aug 29, 2013 | 01:27 PM
Goldcylon's Avatar
Goldcylon
Check the cut bins at home Depot or Lowes (Some times they are free some times they will charge you a couple of bucks). If any home building is going on in your neighborhood ask for permission if you find some usable scraps. They can last you a lifetime and are a solid investment if you wrench on your own car. GC
Old Aug 29, 2013 | 01:34 PM
Goldcylon's Avatar
Goldcylon
Nobody noticed hes welding on a fuel tank either
Old Aug 29, 2013 | 03:49 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by Goldcylon
You have a point? Supporting the use of concrete blocks is a hollow argument.
I sure do have a point. When we behave like alarmists, and make sensational posts like your earlier one claiming the OP "Has a death wish", which he obviously has no wish to die, then that is spreading misinformation to the unwitting. The result? See the quote below. We've scared someone from doing what ever would have likely been a fine, DIY project. Good work. BTW; please quote where I "support the use of concrete blocks". I don't believe that I said that. All I said is that you were being a sensational drama queen about something. For you to say the OP has a "death wish" is totally ridiculous.
Old Aug 29, 2013 | 03:57 PM
mrmtrtrnd's Avatar
mrmtrtrnd
Maybe some of those "suicide bombers" are guys just working on their cars.
Old Aug 29, 2013 | 03:58 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Thats why I love my kwik lift.
Old Aug 29, 2013 | 04:00 PM
Goldcylon's Avatar
Goldcylon
As requested
The two systems presented by the OP were Stands and Concrete blocks.
Which you support as the two systems. Or you would have stated otherwise
I guess reading is not fundamental in Utah.
While I agree with the other posters that it's possible for concrete blocks to fracture and fail
Agreed
Id already advised the OP where he can find the blocks of wood on the cheap. Its "Alarmest" to think hes now scared from doing the project now. Whos being the sensational drama queen now? Great work. Now go bother someone else. However, I already told you that once before.
Old Aug 29, 2013 | 04:07 PM
aklim's Avatar
aklim
Originally Posted by 8valve
Having been a professional Fire Chief for 32 years, now retired, I have see two people crushed dead using Jack Stands that failed. I will never use Jack Stands. I use 6x6" wood cribbing, cross stacked. Its safe, its not going anywhere. Never use concrete blocks as they two can fail.
8Valve
Rubbish. 2X4s are perfectly safe, Mr Fire Chief. Just see the picture attached.
Old Aug 29, 2013 | 07:21 PM
vl5150's Avatar
vl5150
I would never use concrete blocks. Not designed for the purpose and I'm sure the Chinese are into making crappy blocks now too. To many cracked at Home Depot to ever think about getting crushed under a car.
I'm working on my 1st big Vette project now and my car is on jack stands. As an insurance policy I use extra jacks under the car as backup in the event the main jacks fail. I have the ramps and jack stands and for me I prefer the jackstands for the height I can get.
My 3 ton floor jack can have the entire side of the Vette lifted and stabilized in about 2 mins and then repeat on the other side. Done.
Old Aug 29, 2013 | 07:27 PM
  #33
ercriss's Avatar
ercriss
Vl5150,
How high are you lifting your vette?
Old Aug 29, 2013 | 10:26 PM
  #34
kevingib's Avatar
kevingib
My 90 is sitting on 4 - 6 ton stands, wheels off in the garage now. I just measured the height of the stands in the lowest position and they are 19 1/4 floor to perch so my car is about 2 ft off the floor - been like that for about 4 weeks now with plenty of activity going on under and around it.
My stands are good quality and not the grocery store brand. I also use them to work on my 6000 lbs pickup truck and lift it 3 or so feet off the ground on 4 at a time.
30 years of working on cars and nothing has ever fallen.
Old Aug 29, 2013 | 10:53 PM
  #35
Railroadman's Avatar
Railroadman
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
I got a feeling those two dead guys 8valve saw had never had anything fall before, either!
On one of these forums a while back, someone said they were working under their car. Something happened - wife called him for dinner, buddy called on the phone, I forgot what it was. He came back and found the car on the ground because a jack stand had collapsed!
Regardless of WHAT you use, always use TWO unrelated and redundant methods.
Old Aug 29, 2013 | 11:02 PM
  #36
kevingib's Avatar
kevingib
Yes dad. Now I have to go run buy a 4 post lift so I can use my 2x4's as a secondary.
I hate it for the guy that bought the $9 china made stands for his $10 vette.
Maybe you should PM me your contact info so I can add you as a Benny to my life insurance policy. Not being a smart *** but I posted my experience and don't expect at 45 that I am going to get a lecture.
Old Aug 29, 2013 | 11:21 PM
  #37
aklim's Avatar
aklim
Are you sure that was what 8valve saw? Maybe it was a couple of guys who had an "accident" because the wife wanted the life insurance? I have watched a few issues of "Snapped" and I must say that some of the "accidents" look pretty real.
I haven't had that happen yet but getting under the car doesn't make me the most comfortable. I think my TPIS headers that made sure I didn't have to are worth it. I had a set of headers on my F-body that when getting to #8 SUCKED because I had to be under the car. Short of an alignment lift, getting under the car never made me feel comfortable. So I would want it jacked up, jack stand standing by another standing by.
Unless you want to have an "accident" with the wife, claim the insurance and run off with the hot mistress.
To Jack Stand Safety
Old Aug 30, 2013 | 12:14 AM
  #38
vl5150's Avatar
vl5150
Vl5150,
I just measured. 17" from the floor to the jacking point lip. Seems like plenty of lift for doing what I need to do. Removed the X brace (Vert), exhaust, replaced fuel filter, did brakes, rocker arms, clutch fluid. Plenty of room on the bottom and good height for working on the engine from the top without breaking your back bending over.
My ramps don't give me what I need to this kind of work. The spare set of jackstands was $30 so it's small insurance to save your life. I'm going to get a 4th set for this weekend when I muscle the pipes back on.
Old Aug 30, 2013 | 09:07 AM
  #39
1Asterisk's Avatar
1Asterisk
Saving 250 is a nice chunk. Plus you aren't going to throw away your jackstands after one job I hope.
They will come in handy for oil changes and such. Backup blocks can be built yourself for cheap out of wood.
Also when I'm under a car I keep my cell phone in my pocket or laying near. I figure if I do get stuck I can at least call for help. If my wife is away I may text her when I start and finish. If she doesn't hear from me after a normal amount of time she can come check.
Old Aug 30, 2013 | 10:09 AM
  #40
56belair's Avatar
56belair
Default jack
I agree kimmer
www.kwik-lift.com
SO much safer !
