o2 sensor help
Old Sep 3, 2013 | 12:47 PM
Pete919's Avatar
Pete919
Default o2 sensor help
Hi all, finally got my apparently original o2 sensors out of my 94 lt1 6 spd. Had to use heat and other methods to get the drivers side out and in doing so I think I messed up the threads, as the new one won't thread in. I've heard of thread chasers but don't have any. Is this my only option? If so what size? I can't weld so a new position is out. Any help would be appreciated. Thanks.
Old Sep 3, 2013 | 01:32 PM
don hall's Avatar
don hall
This tool should help:
http://www.autozone.com/autozone/acc...er=607067_0_0_
Old Sep 3, 2013 | 05:04 PM
Pete919's Avatar
Pete919
Originally Posted by seabright
I just tried that exact tool, didn't work, any other options, really don't want to go to a shop. Thanks for the response
Old Sep 3, 2013 | 06:36 PM
hooked073's Avatar
hooked073
If what you used did not work try a requler tap I think the threads are m14 just make sure I am right use spray lube work the tap in about 1 or 3 threads then back out a thread or 2 then repeat till ues are done with good thread.
Old Sep 3, 2013 | 07:58 PM
Larry/car's Avatar
Larry/car
Good Luck
Old Sep 3, 2013 | 10:48 PM
Pete919's Avatar
Pete919
I borrowed a tap and followed your suggestions, took a while because of inexperience I guess, but it worked. I really thought it was beyond repair. Thank you very much
Old Sep 3, 2013 | 11:54 PM
hooked073's Avatar
hooked073
That is what this page is for
Old Sep 4, 2013 | 01:15 AM
Phat98's Avatar
Phat98
Don't forget the anti-seize, although most replacement O2 sensors come with a dab on them.
Old Sep 4, 2013 | 10:19 AM
scotth48's Avatar
scotth48
Anti-seize will make it much easier the next time you remove them. I re-fashioned an old 13/16" box end wrench to make it easier to loosen and tighten sensor.
Old Sep 4, 2013 | 11:18 AM
Pete919's Avatar
Pete919
The new ones each came with a packet of anti seize that I used. Had 2 different o2 sensor sockets, even broke a flare nut wrench. Soaked them for 2 days with PB blaster. They were definitely original, 20 years is a long time to be in there I guess.
Old Sep 4, 2013 | 12:20 PM
vrone44's Avatar
vrone44
Would have been a prime opportunity to try the 50/50 acetone atf mix on those O2 sensors.
PB Blaster=ok. A 50/50 mix of acetone & ATF=Best Ever! Here's the cold, hard facts from the April/May 2007 edition of Machinist's Workshop. They did a test of penetrating oils where they measured the force required to loosen rusty test devices. Buy the issue if you want to see how they did the test. The results reported were interesting. The lower the number of pounds the better.
Penetrating oil . Average load .. Price per fluid ounce
None ................. 516 pounds .
WD-40 .............. 238 pounds .. $0.25
PB Blaster ......... 214 pounds .. $0.35
Liquid Wrench ... 127 pounds .. $0.21
Kano Kroil ........ 106 pounds .. $0.75
ATF-Acetone mix.. 53 pounds .. $0.10
To o2 sensor help
