Weird computer problem when under hard acceleration
Old Sep 8, 2013 | 10:35 PM
VeryUnoriginal's Avatar
VeryUnoriginal
Default Weird computer problem when under hard acceleration
I was driving along in my '93 and I found myself getting onto a long, empty highway at 3 a.m. a few months ago, so I decide to "explore the acceleration capabilities". So I stopped, put it in first, revved up to about 2k, let the clutch out and went. I got to about 60 and let off (speed limit's 60).
Here's where things started getting weird, when I let off the "Service ABS" and "Service ASR" lights came on. So I pulled off of the road and turned the car off. Started the car up again and the lights were gone and didn't come back on. About two weeks later I decided to do a 15 mph roll to the speed limit and the same thing happened! Once again, I turned the car off and when I turned it on the lights never came on and I've had no mechanical problems with the car.
I never really addressed the issue because I was trying to sell the car and didn't feel like having to fix it, and I have barely driven it this summer (only about 500 miles this summer). But after looking at other cars to replace this, I realized that I love my C4 to replace it with anything else. So I'm going to keep the car, and I'm going to have to figure out what the hell's going on.
Do any of you guys know what's going on?
Old Sep 8, 2013 | 11:05 PM
84wuzmy1st's Avatar
84wuzmy1st
Typically a bad ABS speed sensor could cause this but sounds like it is having intermittent problems?
Old Sep 8, 2013 | 11:07 PM
Docderek05's Avatar
Docderek05
I would be interested to know how your ASR underhood is adjusted with a manual. with my automatic, sometimes this occurs if my Throttle valve cable is out of adjustment, its a simple fix outlined in the FSM, but for your Manual Trans..not sure how this is adjusted, but could be one lead for you. Best of Luck. do you have access to the FSM for your year?
Old Sep 9, 2013 | 09:25 AM
VeryUnoriginal
Yep! Original Owner bought it for me about two months after I bought the car from him because I kept it in such good condition.
But thank you guys!! Right now I'm in my dorm 2 and a half hours from home. I'll go and look in the FSM next time I go home and see if that works.
Old Sep 9, 2013 | 09:44 AM
toptechx6's Avatar
toptechx6
You may want to try this simple solution first. Top off the brake master cylinder. Stange as it sounds the low brake fluid sensor in the master cylinder can cause what you describe even if the fluid level is just slightly low. The change in level due to acceleration or braking can be enough to trip the switch, good luck.
Old Sep 9, 2013 | 01:05 PM
Bandit's C4's Avatar
Bandit's C4
Central PA Events Coordinator
St. Jude Donor '12-'13
Had a similar problem when running with old brake fluid. A flush and fill with new fluid eliminated that problem for me.
Old Sep 9, 2013 | 05:25 PM
VeryUnoriginal
So low brake fluid would make the Service ASR light come on too? The Service ABS light is a given, but I'm not following how the ASR light would come on as well. I know the two are interconnected, but it's not clicking in my head as to why.
Old Sep 10, 2013 | 06:33 AM
toptechx6's Avatar
toptechx6
ASR is part of the ABS system, the low brake fluid code (83) will disable them both. Page 5E2-124 in book #1 of the 93 FSM.
See Page 8D-4 to learn how to display fault codes from ABS and other controllers using the speedometer display.
Old Sep 12, 2013 | 09:03 PM
Macs94's Avatar
Macs94
Navigator
Default ASR/ABS lights on under hard acceleration....
;1584873369]I was driving along in my '93 and I found myself getting onto a long, empty highway at 3 a.m. a few months ago, so I decide to "explore the acceleration capabilities". So I stopped, put it in first, revved up to about 2k, let the clutch out and went. I got to about 60 and let off (speed limit's 60).
Do any of you guys know what's going on?[/QUOTE]
Old Sep 12, 2013 | 09:11 PM
Macs94's Avatar
Macs94
Navigator
One possibility is: Since the ASR and ABS both are functions of operation of the braking system. Since it occurs under accel, and clears when the switch is turned off and then back on it sounds like, ARE YOU Ready????? The fluid is low in your master cylinder. Rear thrust of the car sends the fluid in the reservoir to the rear and low fluid then allows the sensor, located at center and slightly below the middle of the plastic housing to turn on.... Be sure not to over fill and DO use the correct fluid or you will have far more issues than just a light on.
Good luck.
Mac
Old Sep 12, 2013 | 09:29 PM
VeryUnoriginal
Thanks guys! I'll make sure to try the fluid and see if that fixes it.
Old Sep 12, 2013 | 10:18 PM
1993C4LT1's Avatar
1993C4LT1
Hell yeah man! Glad you're keeping the C4.
Good luck on the fix.
Old Sep 13, 2013 | 09:38 PM
VeryUnoriginal
Thanks! I was originally going to buy a 04-05 CTS-V once the C4 sold, but that's life. I'll just save until I can afford both. American M5 fighter!
Old Sep 13, 2013 | 09:49 PM
1993C4LT1's Avatar
1993C4LT1
Nice, those cts v's are sweet. I'm saving up for a second Vette or an e36 M3.
Old Sep 14, 2013 | 02:57 AM
VeryUnoriginal
Not a bad plan! I've recently gotten into beamers, and I'm really hoping to find an E49 wagon right now. Just waiting for a good one with a manual to show up.
To Weird computer problem when under hard acceleration
